Detroit Locker - JeepForum.com
post #1 of 16 Old 07-06-2012, 06:13 AM Thread Starter
acurrier2012
Detroit Locker
My 01 Cherokee has Detroit Lockers. When i put the jeep into either reverse or into drive, a big "thud" happens. Is this the Detroit Locker "locking in", or should i be worried?
acurrier2012 is offline
post #2 of 16 Old 07-06-2012, 06:22 AM
KingtheZJ
how big is the thud?
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #3 of 16 Old 07-06-2012, 06:25 AM
CGrugger
CGrugger's Avatar
I hope it isnt as big as his text is...
2005 TJ X: 2" RE spacer lift, 32"x11.5" tires, 1.25" Zone body lift, Curry Antirock sway bar.
CGrugger is offline
post #4 of 16 Old 07-06-2012, 06:26 AM
KingtheZJ
that could be a big thud
'88 XJ
post #5 of 16 Old 07-06-2012, 06:50 AM Thread Starter
acurrier2012
Ya didnt mean to do that text.. Its not crazy big, but its noticeable. Is that normal? If not, what should be looked at? New to Jeeps.
post #6 of 16 Old 07-06-2012, 06:54 AM
KingtheZJ
haha we're just messing with you.
ive never seen a detroit locker in action, but it is supposed to be a "soft locker". i wouldnt expect it to thud too much. check suspension parts for paly
'88 XJ
post #7 of 16 Old 07-06-2012, 06:58 AM Thread Starter
acurrier2012
Probably should get it checked out. Thanks for the info.
post #8 of 16 Old 07-06-2012, 07:06 AM
Technohead
In 2wd or 4wd (or both?)
Are you sure they are Detroit lockers? I have a Detroit locker in my rear axle and it is virtually unoticeable . . . except when I need traction in which case it works magic!
My suspicion is that you have lunchbox lockers such as Aussie or Lock-Rite which can be quite noisy.
-Eric
Technohead is offline
post #9 of 16 Old 07-06-2012, 07:12 AM Thread Starter
acurrier2012
Mostly just in 2wd, but sometimes in 4wd.
I am positive i have Detroit Lockers, but i am not positive that thats what the noise is. Several people told me that may cause it, but it still has me wondering.
post #10 of 16 Old 07-07-2012, 06:25 AM
fbv193
When I first installed the Detroit Locker in my YJ, the first thing I noticed was a "thunk" when putting in gear, either forward or reverse. By its nature, an automatic locker such as the Detroit has a bit of rotation or "slack" in the ring gear before axle shafts are turned, as opposed to an open or LS diff. I dont think about it any more, but it is still there. I suspect that is what you are hearing, the ring gear and carrier rotating and then abruptly stopping as the slack is taken up.
fbv193 is offline
post #11 of 16 Old 07-07-2012, 07:26 AM
jason m
Nothing but the facts
jason m's Avatar
If its a full case locker then yes it will clunk when it locks and un-locks.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #12 of 16 Old 07-09-2012, 06:06 AM Thread Starter
acurrier2012
Thanks for the info guys. Looks like ill just leave it how it is.
post #13 of 16 Old 07-09-2012, 06:06 AM
SLADE
I don't think the Detroit is the cause.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #14 of 16 Old 07-09-2012, 06:09 AM Thread Starter
acurrier2012
What would you suggest?
post #15 of 16 Old 07-09-2012, 06:32 AM
SLADE
Transmission.
ring/pinion slop.
Axle wrap.
Have someone shift it from forward to reverse while you watch undernieth it and see what you see. You need to better narrow down your problem and where the noise is coming from.
Ive had a few Detroits and Ive never heard them make any noise when shifting from forwards to reverse. They typically unlaod (thud) when they are on a bind (turning). I'm not saying that it is not the Detroit, but it will be in your best interest to rule out all the other possibilities.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
cherokee , detroit locker , jeep
Stock front locker with Detroit rear locker wiring question RallyeX Engines & Drivetrain 2 06-13-2011 11:45 PM
Detroit Locker 4x4Mudmonster Engines & Drivetrain 2 07-01-2008 09:14 PM
detroit locker??? nyjeeperman General Jeep & Off-Road Equipment 13 01-29-2006 11:03 PM
Detroit EZ Locker ?? kg6mti General Jeep & Off-Road Equipment 0 11-22-2004 11:04 PM
detroit locker on a 2wd ZJ? jlr69s General Jeep & Off-Road Equipment 4 03-11-2003 11:38 PM
