Destroyed CV ball assembly - JeepForum.com
post #1 of 6 Old 04-06-2012, 10:55 AM Thread Starter
Kodiak17
After taking my front driveshaft apart today, I found the culprit of my destroyed t-case. The CV centering ball was obliterated. I already have a the ball kit, but need the yoke. Problem is, theres something welded to the tip of my driveshaft that was also warped from the carnage. How do I go about fixing this?
Centering ball assembly:
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #2 of 6 Old 04-06-2012, 03:14 PM Thread Starter
Kodiak17
bump
Kodiak17 is offline
post #3 of 6 Old 04-06-2012, 09:06 PM Thread Starter
Kodiak17
bump again
Kodiak17 is offline
post #4 of 6 Old 04-08-2012, 09:03 AM
wgirvine
1992 XJ Cherokee
Hate to tell you this, but you're going to need a new driveshaft. That "obliterated" part is the pin where the centering ball sits. Maybe one of the big driveshaft shops has a repair...
BTW, the centering ball has a very small, flush zerk fitting. You use a special adaptor on your grease gun, and lube the centering ball every 3 months or so. Then you won't have this problem. Don't feel bad; everyone forgets to lube this part.
The road goes on forever, the party never ends....
wgirvine is offline
post #5 of 6 Old 04-08-2012, 12:14 PM Thread Starter
Kodiak17
Well I learned the hard way I guess. So could I pull one from a JY? And would the driveline shops just cut and reweld a new one?
Kodiak17 is offline
post #6 of 6 Old 04-09-2012, 12:22 PM Thread Starter
Kodiak17
Quoted $70 for repair and re-balance from a shop. Found some used shafts running $75-100. Which one?
Kodiak17 is offline
Destroyed Transfer Case weems Engines & Drivetrain 4 03-27-2010 02:05 PM
Destroyed detroit locker which one to buy now??? chris78cj7 Engines & Drivetrain 2 01-07-2010 08:54 AM
Destroyed Dana 35 XJcrazy00 Engines & Drivetrain 10 09-23-2008 08:48 PM
Destroyed Gears *with pics* EaglesSJ Engines & Drivetrain 12 12-17-2006 03:33 PM
MJ destroyed....Due to drunk... SoloCamo Street Jeep Forum 9 09-11-2006 07:23 PM
