Derale Trans Cooler Need Help! - JeepForum.com
post #1 of 10 Old 12-27-2015, 03:53 PM Thread Starter
TJTurbo
I have different transmission lines than what's shown in the instructions...looks like crimped connections. I'm not sure what would be the best way to splice into the lines.
TJTurbo is offline
post #2 of 10 Old 12-27-2015, 04:16 PM Thread Starter
TJTurbo
This is for a 2006 Jeep Wrangler. Everything I have found online shows the rubber transmission hoses clamped to the lines and radiator not crimped. Would it be possible to cut the rubber hose in the middle and use some type of adapter or even a short piece of metal transmission line? I've never messed with transmission lines before and I'm hoping somebody else has run into this before.
TJTurbo is offline
post #3 of 10 Old 12-27-2015, 04:19 PM
biffgnar
biffgnar's Avatar
When I installed a supplemental transmission cooler I just cut the soft line and used brass hose barbs.
Romney in 2020!
biffgnar is online now
post #4 of 10 Old 12-27-2015, 04:27 PM Thread Starter
TJTurbo
I figured I could do something like that but I was worried about restricting the flow of the trans fluid.
TJTurbo is offline
post #5 of 10 Old 12-27-2015, 04:30 PM Thread Starter
TJTurbo
I've got the 42RLE so is the driver's side line the one I should splice into?
TJTurbo is offline
post #6 of 10 Old 12-27-2015, 04:56 PM
biffgnar
biffgnar's Avatar
Depends whether you want your cooler before or after the stock cooler. Opinions vary as to which way to go.
Romney in 2020!
post #7 of 10 Old 12-27-2015, 04:58 PM
biffgnar
biffgnar's Avatar
If flow is restricted in my setup it doesn't seem to causing a problem. 158k miles and counting with no problems., which is probably on the high side for 42RLE.
Romney in 2020!
post #8 of 10 Old 12-27-2015, 06:06 PM Thread Starter
TJTurbo
Yea doesn't sound like it would restrict it at all. Did you use a 3/8 barb like you get at the hardware store? I've also seen where a few people have actually just cut the metal crimped part off the line then just slide the new line on and clamp.
TJTurbo is offline
post #9 of 10 Old 12-27-2015, 06:17 PM
biffgnar
biffgnar's Avatar
Used 3/8" brass hose barbs from McMaster Carr and hose clamps.
Romney in 2020!
post #10 of 10 Old 12-27-2015, 06:34 PM Thread Starter
TJTurbo
Thanks biffgnar!
TJTurbo is offline
