Dana35 spider gear issue - JeepForum.com
post #1 of 7 Old 09-19-2013, 02:29 PM Thread Starter
cory4um
The spider gears are loose in the diff..
99xj almost 200k miles.
The gears on the cross shaft are loose, side gears appear to be ok.
I was just wandering where to buy, local, the thrust washer/spacer to install behind the spider gears. Part# and stores would be awesome or any info..
Figure do a fluid change and general maintenance while i have a spare vehicle for the week.
Have a whine noise above 40mph and wouldn't mind spending the 20$ or so to see if it fixes it. I found spider kits, but not wanting to spend the 80+$ for spider gears.. Maybe its the pinion bearing but would rather swap in a 8.25 or 8.8 before going that far into it. Rear diff swap is in the future.
Ring and pinion appear to have good contact pattern, and appearance of spidergears look good (no damage or chips)
cory4um is offline
post #2 of 7 Old 09-22-2013, 11:25 AM
Evildriver-3
The whine isn't spider gears, see your local driveline shops for diff stuff and gears. In many cases there is some play in the spiders so loose may be fine, and what is loose as defined ?
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
post #3 of 7 Old 09-22-2013, 10:56 PM
uberxj92
1992 XJ Cherokee
What axle is it? Where us the whine coming from? Could be bearings.
If you go with 8.25 swap you will have to pull the fuse and relay for the abs if you have it.
8.8 is awesome.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #4 of 7 Old 09-23-2013, 07:54 AM
Evildriver-3
It's a D-35
]=Supershafts=[
post #5 of 7 Old 09-23-2013, 08:13 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Spider gears won't cause a whine.
You will want to tell us when it happens. Under load, coasting, all the time, etc.....
Usual causes are pinion/carrier bearings.
jeepdaddy2000 is offline
post #6 of 7 Old 09-25-2013, 08:26 PM Thread Starter
cory4um
It is the d35.
The gears are loose as in the gear can move side to side on the shaft, maybe 1/8"or more. Also up and down on shaft.
If you want, several youtube vids on the d35 spider gears are out. Mine looking the same.
Loud whine any time im pushing the accel, 35+,mph..
It's been loud.since i bought the jeep.. Almost 100k miles ago.
Im certain its the pinion. No leaks, change fluid seasonally..
Abs will be taken care of, looking to go to disks if i do the swap.
I've been waiting (wanting) for the rear to blow, but it's holding on for a long time now..
cory4um is offline
post #7 of 7 Old 09-25-2013, 09:16 PM
uberxj92
1992 XJ Cherokee
If you go 8.25 you can use the disc brakes of off s zj d35. Easy upgrade.
I have 3 xjs all with 8.8's. $300 to have them welded professionally. That's including the axle price. I've never looked back since.
uberxj92 is offline
