#31 | ||
You will really be suprised as to what they can handle and how far you can push them, i was. And its a axle that can grow with you and your wheeling needs. Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money. |
#32 |
i have a 79 f250 hpd44. i wish i had a hp 60 but hard to come by. will a hp44 last with 37s. i think it will be ok, not overkill like the rear,but just ok. what do you think
tellicojeeper |
#33 |
got my 44 home today. it has 4.10s, so i might run factory gearing for a bit, so i can spend $ money on new ball joints and bearings. to get a crossover steering setup, i just swap the passenger side knuckle with a chevy one, correct? does it matter that its a 8 lug and the chevy knuckle i got is a 6 lug. sorry guys but im new to big gear game.
tellicojeeper |
#34 |
it has drive flanges instead of lockouts. which should i use?
tellicojeeper |
#35 | |
Its the same part number for the balljoints. I would use the drive flange's, there stronger than hubs. Are they internal or external flange's. Jason.
#36 |
they dont use the bolt on caps like aftermarket ones. has just a clip that holds them on. they look like lockouts with something missing. i can try to post apic of them tomorrow.
tellicojeeper |
#37 |
i am thinking about the rockcrusher ones, look beefy. have any thoughts
tellicojeeper |
#38 |
my front wheels arent hub centric. like a 1/4" gap all the way around the hub centric part of the wheel. is this common with the older 8 lug d44?
tellicojeeper |
#39 |
what brackets should i get. i was thinking about the tnt truss, can get it with everthing set already
tellicojeeper |
#40 |
jason, i checked some pics on pirate4x4. looks like mine are internal flanges being held in by a clip. time to upgrade. do you think the heavy duty dana 44 will last with 37s.
tellicojeeper |
#41 | |
Unlike king pins all i do is greese them, in fact over the 4 years theve been on my jeep ive never touched them. They came straight out of the 88 F-350, pulled the knuckle off checked them out and re-assemabled them, done. Keep searching I'm sure theres 60 someware in the area. You were saying your Dad gets alot of chevy trucks. Grab one of them, even if you need to run a pass side drop T-case its worth the extra work. Ive seen alot of peaple try to build a 44 to handle there needs only to let down after the first breakage. I would run a 60 even if i had 35's there stupid strong and for what i do ( and alot of peaple that run them ) they really are hard to break. I have the same stock axle for 4 hard years now with all stock parts and i never broke. Trust me i try, ive put myself in spots were i was sure i was going to break it, but no it doesn't let me down.Keep searching for a 60 and dont get to carried away with that 44, spend your money once. Jason.
#42 |
thats the financial plan or goal. i will try to look for a 60. might just go ahead and put some brackets on the 44 for temp. then sell once a 60 comes along. always someone lookin for a 44
tellicojeeper |
#43 | |
(Sorry about all the questions, i'm about to build my rig similar to yours...40's, D70 rear, etc...)
My Build Thread -->http://www.jeepforum.com/forum/f22/taala-2-build-thread-1163594/ "I joined this jeep club to wheel. If I wanted to socialize I would have joined a book club..." |
#44 | ||
Now in the 937
4.0L/NV3550/D300. I've put about 3000 miles on it like this, it works.
The lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase Build thread here. Quote:
Pictures of it wheeling at Bill's 491 And more pics from that trip here! |
#45 |
14 bolt. Cheap parts cause everybody has them and you can make them super badass. Xtreme 4x4 did a steering shaved one. A lot of buggy guys run front and rear. Check out Madram11 on YouTube for the buggies
[COLOR="Indigo"]Purple Jeep Club member #13[/COLOR] |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
