Dana 44 rear axle - JeepForum.com
post #1 of 4 Old 04-12-2008, 04:31 PM Thread Starter
khoward1972
Dana 44 rear axle
I just bought a 2000 jeep sahara and was wondering how to tell if mine had the dana 44 rear axle. any info would be much help. thanks in advance
khoward1972 is offline
post #2 of 4 Old 04-12-2008, 08:15 PM
Robbypfd
Go to the YJ forum and then click on FAQ from there scroll down to the bottom of the page. This should help you out.
Rob
Robbypfd is offline
post #3 of 4 Old 04-12-2008, 09:03 PM Thread Starter
khoward1972
thank you
post #4 of 4 Old 04-14-2008, 08:18 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
There is a sticky in the TJ forum titled "Stock TJ Specifications" that has all kinds of info like this.
Here is some info on stock TJ axles copied from that thread:
Originally Posted by Wheelin98TJ View Post
Axles
Dana 30 (181 mm) - 1997-2006
* Front axle used on all TJs except the Rubicon model
* Stock gear ratio options = 3.07, 3.55, 3.73, 4.10, 4.56
* Carrier break = 3.55 / 3.73
* Open carrier - no Trac-Lok limited slip option
* Ring gear diameter = 7.125"
* Ring gear bolts = (10) 3/8 x 20 RH
* Low pinion (short pinion)
* Pinion shaft diameter = 1.376"
* Pinion shaft spline count = 26
* Axle shaft diameter = 1.16"
* Axle shaft spline count = 27 both inner and outer
* Axle shaft u-joints = 5-760x / 5-297x
* WMS-WMS = approximately 60.5"
* 5 on 4.5" bolt pattern
Dana 35c (194mm) - 1997-2006
* Standard rear axle used on all TJs except the Rubicon model
* Carrier break = 3.31 / 3.55
* Optional Trac-Lok limited slip differential
* Ring gear diameter = 7.5625"
* Ring gear bolts = (8) 3/8 x 24 RH - NOTE: 7/16" used on later model TJs
* Low pinion
* Pinion shaft diameter = 1.406"
* Rubber pressed-in fill plug
Dana 44 (216mm) - 1997-2006
* Optional rear axle used on 6 cyl models except the Rubicon model
* Stock gear ratio options - 3.55 (97 only), 3.73
* Carrier Break = 3.73/3.92
* Standard Trac-Lok limited slip differential on early model TJs / Optional on later model TJs
* Ring gear diameter = 8.5"
* Ring gear bolts = (10) 3/8 x 24 RH - Note: 7/16" used on later model TJs
* Low pinion
* Axle shaft diameter = 1.30"
* Axle shaft spline count = 30
* Threaded 3/8" fill plug
Dana 44 (216 mm) Rubicon- 2003-2006
* Standard front axle used on all Rubicon model TJs
* 4.10 gears
* Tru-Lok selectable pneumatic locker - open differential when unlocked
* Ring gear bolts = (10) 7/16" x ??
* Low pinion
* Axle shaft spline count = 30 inner / 27 outer
Note: The outer axle shafts, unit bearings (hubs), knuckles, and brakes are the same as those found on the TJ D30.
Dana 44 (226 mm) Rubicon - 2003-2006
* Standard rear axle used on all Rubicon model TJs
* 4.10 gears
* Tru-Lok selectable pneumatic locker - limited slip differential when unlocked
* Low pinion
Wheelin98TJ is offline
dodge dana 60 rear axle question 488TJ Engines & Drivetrain 6 11-22-2009 09:25 AM
dana 44 rear axle shafts size Butch03tj Engines & Drivetrain 2 02-22-2008 07:32 PM
J4000 Rear Dana 60 Front Dana 44 axle swap into a J4000 coastie124 Engines & Drivetrain 0 04-05-2007 10:26 PM
Rodeo Dana 44 rear axle. BackRoadJPin Engines & Drivetrain 7 06-11-2006 09:22 PM
Currie Rock Jock Dana 60 rear axle? ps3tv Engines & Drivetrain 4 04-18-2006 09:37 AM
