Dana 44 Narrow Track - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Dana 44 Narrow Track
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 04-27-2011, 05:55 PM   #1
RussellZJ98
I found a Dana 44 narrow track front axle housing out of an '89 grand wagoneer. I am curious about the axle shafts from my dana 30 swapping over into this axle. I figured it would be a no, but when I searched for axle shafts on autozone's website, the shaft it gave me for the 89 grand wagoneer, and for my 98 grand cherokee have the same part number. I'm really hoping I can use my axle parts to swap over onto this stripped axle. Can anyone verify?
RussellZJ98 is offline   Reply With Quote
Unread 04-27-2011, 07:57 PM   #2
Technohead
Old school
Technohead's Avatar
Since its almost always the axle shafts that break, what do you hope to gain by swapping in a D44 and using the same shafts? Get some alloys for you D30 and wheel it.
Technohead is offline   Reply With Quote
Unread 04-27-2011, 07:58 PM   #3
BriansCJ
1994 XJ Cherokee
They wont fit, different spline count and the length is a little off too I think.
5 Speed XJ Build - Daily Driver & Weekend Wheeler
1978 CJ5 Resto, w/ heavy mods - Slow
BriansCJ is offline   Reply With Quote
Unread 04-27-2011, 11:06 PM   #4
RussellZJ98
Thats what I figured. I bent my dana 30 pre running. Spline count is off, The 44 has 30 spline.
What about my knuckles?
Unread 05-02-2011, 04:30 PM   #5
RussellZJ98
So after some research, my zj dana 30 uses the same 297 u joint that the narrow track dana 44 does. But the ball joints are not the same. So I am trying to decide if my dana 30 knuckles will fit onto the ball joints of the 44. If so, I should be able to mount my d30 knuckles onto the dana 44, use my dana 30 outer shafts and d30 hub assemblies, and d44 inner shafts. I realize I am retaining the weak d30 assemblies from the inner shaft out, but those are easy to replace. And I have to be able to drive my jeep to work in order to pay for upgrades. I understand the low torque breaking of axle components, but this is mostly a prerunner. I have bent 2 axle tubes now, and never had a problem with the shafts, bearings, or knuckles because quite simply, my tires dont get enough traction on the sand to break these components (at least yet). I am mostly trying to get my d44 in and running until I can upgrade. Any input?
