dana 44 hub swap??? - JeepForum.com
post #1 of 3 Old 05-02-2012, 08:46 AM Thread Starter
turnebr
1980 CJ7
dana 44 hub swap???
i currently have a high pinion dana 44 out of a full size bronco but it will not work very well with my drive train as to the fact that is has a driver side differential so iv been looking for someone that has a gm or chevy dana 44 which should have a passenger side differential but none of them have the 5x5.5 lug pattern.
question, can you swap the hubs from the ford axle to the chevy axle in order to keep the 5x5.5 lug pattern? are there any modifications to the axle housing that would need to be done? what about the brakes?
thanks for the help
Jeeps and girls are alot alike, both get mad when you call them the "c word", both like to be rode hard, both of them are hard to control... Hell, the only difference between them is you can only fix one with a hammer.
turnebr is offline
post #2 of 3 Old 05-02-2012, 09:50 AM
RedlegWJ
If you swap knuckles, you'll need to use the appropriate stub shaft with it's hub. Otherwise, read here about swapping spindles and hubs. http://77cj.littlekeylime.com/web_rs44.html
Gray 99 Laredo with '04 driveline wap. Tons of fun coming soon. Steel bumpers. 5 1/2" IRO coils, IRO adj. track bar. Rancho RS9000 Addco rear sway. 2"x.250" DOM long arms with johny joints. Custom A-arm with ball joint delete (J-joint). JK Moab wheels/ 33x 12.5 x 17 Cooper SST. Bushwacker Flares.
RedlegWJ is offline
post #3 of 3 Old 05-02-2012, 06:54 PM
BlueRubiconrich
you could use a Scout 2 Dana 44 front end.all your CJ hub parts will bolt up.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
Dana 44 Swap 350JeepCj5 Engines & Drivetrain 3 09-05-2011 06:55 AM
dana 44 swap xitsjaybird90 Engines & Drivetrain 2 03-16-2009 11:51 AM
Swap Dana 20 for Dana 44 Chasebo Engines & Drivetrain 2 02-13-2009 08:35 AM
J4000 Rear Dana 60 Front Dana 44 axle swap into a J4000 coastie124 Engines & Drivetrain 0 04-05-2007 09:26 PM
XJ Dana 44s swap to a YJ ?? is it possible?? FunkSkunk General Jeep & Off-Road Equipment 2 06-22-2002 02:09 PM
