dana 44 housing - JeepForum.com
post #1 of 20 Old 02-21-2007, 10:42 PM Thread Starter
elkfan2
elkfan2's Avatar
dana 44 housing
I was wondering if the housing of a dana 44 is any stronger than the housing of a dana 35. I've been told they are the same strength. Just the housing, not the ring gears. or axles.
elkfan2 is offline
post #2 of 20 Old 02-22-2007, 09:45 AM
Lud04X
I know the axle tubes of the D35 and TJ D44 are exactly the same. Not sure about the rest.
Khaki 2004 Wrangler X
OME HD Kit,JKS BMML,1.25 JKS BL, adj. control arms
RE Generation II Quick Discos
35x12.5x15 Goodyear MTR's w/ Kevlar, MT Classic II's
D44 rear axle w/ ARB, alloy shafts, 4.56 gears
Dana 30 with ARB, 4.56 gears, alloy shafts and ujoints
Lud04X is offline
post #3 of 20 Old 02-24-2007, 10:51 AM
crgrissom
Master of Reality
crgrissom's Avatar
Just looking at them side-by-side (I compared them when I did my swap) the D35 looked kind of puny. there is no way the D44 housing is not significantly stronger, just based on the size comparison.
Chuck
Chuck Grissom
Opportunity is missed by most people because it is dressed in overalls and looks like work.
- Thomas A. Edison
crgrissom is offline
post #4 of 20 Old 02-24-2007, 05:58 PM
MQ79
They use the exact same tubes. So the answer is that both housing are virtually the same strength.
Some people make the argument that the larger center section on the Dana 44 makes the housing stronger then the Dana 35. But truly, any difference in housing strength would be minimal.
The best advise would be to the truss the housing on either of them.
MQ79 is offline
post #5 of 20 Old 09-24-2007, 06:10 PM
waynehartwig
www.jeeperman.com
waynehartwig's Avatar
1946 CJ2A
They are not the same... Next time you have a M35 and a D44 sitting side by side, measure again.
The M35 necks down when it goes into the pumpkin - the D44 does not. That necked down area is where all of the M35's break.
So try again...
1946 CJ2A Ultra4 Race car, street legal!
waynehartwig is offline
post #6 of 20 Old 09-24-2007, 06:12 PM
waynehartwig
www.jeeperman.com
1946 CJ2A
D'oh! I mean they are weaker! So sell me your D44 TJ housing
...Seriously, I need one for a customer.
post #7 of 20 Old 09-26-2007, 11:17 PM Thread Starter
elkfan2
elkfan2's Avatar
So when I first posted this I was deciding between a super 35 and a dana 44 had the money to go either way and decided to save a little and go with the super 35, what a waste that was because it only lasted 5 months and now I have the dana 44 any way. The super 35 guts held up fine other than twisted splines on the right axle but I beleive that was cause by the centersection breaking and the right axle tube twisting. Hopefully the centersection of the dana 44 is stronger, sure looks like it will be.
elkfan2 is offline
post #8 of 20 Old 09-27-2007, 08:55 AM
waynehartwig
www.jeeperman.com
1946 CJ2A
This is exactly why I just about refuse to sell a Super 35 kit (and I carry them all, Yukon, Alloy USA and Superior). They are a complete waste of money. As you unfortunately learned, the guts aren't the problem with the 35... I sell built D44's for only a few hundred more than a Super 35 kit. Were you at least able to salvage the locker and sell it seperately?
...Same thing with a Tera Low. Don't bother with that either. For only a few hundred more you can have a Stak or Atlas; basically the same price as a SYE and Tera Low. I tell my customers if they don't have the coin for the new case, put the SYE in their 231 and wait. A SYE'ed 231 is easy to sell later for a pretty hefty down payment on a much much stronger TCase.
Oh, and to Lud04X... IF the M35 and D44 have exactly the same tubes, why aren't you breaking your D44 with those 4.56 gears, ARB and 35" tires? You tell me ONE M35 rear end that can even hold up to that. You can't; because your statement is BS. (Sorry, not attacking you personally, just your ignorance on the topic )
post #9 of 20 Old 09-27-2007, 12:03 PM Thread Starter
elkfan2
elkfan2's Avatar
[QUOTE=waynehartwig]This is exactly why I just about refuse to sell a Super 35 kit (and I carry them all, Yukon, Alloy USA and Superior). They are a complete waste of money. As you unfortunately learned, the guts aren't the problem with the 35... I sell built D44's for only a few hundred more than a Super 35 kit. Were you at least able to salvage the locker and sell it seperately?
No I wasn't able to salvage the locker becaue when the splines of the axle twisted they got locked in the locker and the locker broke when trying to get the axle out. So Chalk one up to experience, it's funny how many people try to justify building a dana 35. I think the people that have a super 35 and say it's strong are just trying to make themselves feel better for the purchase.
elkfan2 is offline
post #10 of 20 Old 09-27-2007, 01:19 PM
waynehartwig
www.jeeperman.com
1946 CJ2A
[QUOTE=elkfan2]
That sucks! I could probably get you the parts to repair it?
I think the only way to make a M35 live is by adding a full width truss; like the Superior one that is also a diff cover... But even then, why bother?
post #11 of 20 Old 09-27-2007, 02:11 PM
wonderboy
So what is the problem?
How much for one of your axles?
wonderboy is offline
post #12 of 20 Old 09-27-2007, 02:46 PM
waynehartwig
www.jeeperman.com
1946 CJ2A
The housing...
Super 35 kit is $949
http://www.4wd.com/productdetails.aspx?pid=S35C
TJ D44 rear ready to bolt in with your choice of gears and 33 spline axles is $2139
http://www.alljeep.com/oscommerce/pr...ucts_id=165947
Granted it is almost 2k more, but when you consider the benifits and the fact it's all brand new with new gears (perfect time to change the front, too!) and 33 spline axles, it's just a way better option!
post #13 of 20 Old 09-27-2007, 02:51 PM
wonderboy
I don't know about you, but $1100 more is not "a few hundred". I understand what you mean about it being a better axle, but some of us can't drop an extra grand for an axle.
post #14 of 20 Old 09-27-2007, 03:45 PM
waynehartwig
www.jeeperman.com
1946 CJ2A
I understand; but if you are looking for a cheap sport, try softball. Spend the $1k now, and then spend $2k later when the Super 35 blows up - because it will! That's $3k... You could have gone to Vegas and at least had a good time with that $1k; if you are just going to piss it away like that...
I was trying to find the cost of a Super 35 kit with OX locker. I want to say it was right around $1400. I just sold 2 TJ D44's with OX lockers (still need to build them) for ~$2200... What's that, $800 difference? It'd cost you that much to have a shop regear that POS 35 and add the Super 35 kit.
post #15 of 20 Old 09-27-2007, 03:47 PM
wonderboy
I completely agree with you, i just wish i had that kind of money.
Dana 60 axles in Dana 44 housing external hubs dustydoggy Engines & Drivetrain 1 03-26-2009 12:39 AM
Gear guys - Aluminum housing Dana 44 (D44HD) - excess rotational play? FPKites Tires & Wheels 6 11-02-2008 07:45 PM
Dana 300 speedo drive gear housing JIA Engines & Drivetrain 0 07-17-2008 12:08 PM
Drilling axle housing for Dana 30 ARB? Lud04X Engines & Drivetrain 2 04-18-2008 02:21 PM
D35 is it the axle or the housing? Brett-n-GA General Jeep & Off-Road Equipment 14 05-18-2004 08:20 PM
