Dana 44 conversion - JeepForum.com
post #1 of 4 Old 05-03-2012, 06:38 PM Thread Starter
SJCFORD
1974 FSJ Cherokee
Dana 44 conversion
Ive got a 1974 Jeep Cherokee Sport and it has a dana 44 in the front with automatic locking hubs. id like to be able to convert it to manual locking hubs. is there any cheap way of doin this?
SJCFORD is offline
post #2 of 4 Old 05-03-2012, 10:22 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
First, be sure your not running a Q trac transfercase. If you are, you will have to convert it to part time in order to unlock the front axle. If all is well, then it is a simple step to purchase a set of manuals and install them.
jeepdaddy2000 is offline
post #3 of 4 Old 05-03-2012, 10:42 PM Thread Starter
SJCFORD
1974 FSJ Cherokee
It actually does have a quadra trac transfer case. so being that so do they sell kits to make them part time transfer cases.
SJCFORD is offline
post #4 of 4 Old 05-04-2012, 05:24 AM
jeepdaddy2000
1971 CJ5
http://milemarker.com/products/drive...ts-accessories
A bit spendy, but comes with a new chain as well. You can also get it with an OD sprocket if your looking to lower your RPM's a bit. They are also very easy to install.
Dana 44a to 44 conversion SGT_Jeep Engines & Drivetrain 8 04-15-2012 12:53 PM
Dana 44 conversion to Auto locker ApolloXIII Engines & Drivetrain 11 11-22-2011 07:07 PM
WARN hub conversion on a DANA 44 ? Challenge TJ Engines & Drivetrain 0 12-17-2007 09:01 PM
dana 60 FF conversion NOTQUITEMUSASHI Engines & Drivetrain 3 06-28-2007 09:03 AM
Dana 44 hub conversion JOKER4INK General Jeep & Off-Road Equipment 2 09-28-2005 12:23 PM
