Dana 44 clunking and tire slop (rear) - JeepForum.com
post #1 of 5 Old 01-15-2012, 09:12 PM Thread Starter
H2oboy21
I have a clunking noise coming from the driver side rear tire. It was most noticeable when coasting but not accelerating. I could move the tire side to side and hear the clunk. I thought it was the wheel bearing causing the noise. I had the bearing and retainer ring replaced. I also replaced the oil seal and outer bearing retainer. There is still too much end play on the shaft. The clunk is still there. It has the exact same sound when driving. There is nothing left to replace. I also made sure the nuts on the outer bearing retainer were tight. Am I missing something?
The only thing I can think is bent axle shaft? Please help
1998 jeep wrangler 4.0l
Dana 44, 4.10 gearing, 30 spline.
P.s : I have checked the tightening of all the bolts.
H2oboy21 is offline
post #2 of 5 Old 01-16-2012, 12:51 PM
RedlegWJ
There is always some "slight" looseness, the axle needs to push in slightly for c- clip removal at the planetary. Check inside to se if you have excessivly worn c-clips and center pin. C-clips do wear out and fail, which is something you dont want to experience on the road.
Gray 99 Laredo with '04 driveline wap. Tons of fun coming soon. Steel bumpers. 5 1/2" IRO coils, IRO adj. track bar. Rancho RS9000 Addco rear sway. 2"x.250" DOM long arms with johny joints. Custom A-arm with ball joint delete (J-joint). JK Moab wheels/ 33x 12.5 x 17 Cooper SST. Bushwacker Flares.
RedlegWJ is offline
post #3 of 5 Old 01-16-2012, 04:52 PM Thread Starter
H2oboy21
Thanks for the reply, however you might be mixed up with the Dana 35. The Dana 44 has pressed on bearing with a retaining plate that holds the axle shaft in, there are no c-clips. On my passenger side rear the tire is solid with no movement and or clunking.
H2oboy21 is offline
post #4 of 5 Old 01-16-2012, 07:07 PM
RedlegWJ
Actually, I had just been in the Grand Cherokee section and when I glanced at 1998 in your sig, ZJ is what came to mind, which does use a c-clip 44. Still my bad. Maybe pull the other side to compare and see for sure that the new bearing was pressed on equally?
RedlegWJ is offline
post #5 of 5 Old 01-24-2012, 10:33 AM Thread Starter
H2oboy21
Ok the issue has been found! The spider gears were chunked and so worn down that it was allowing the shaft to move. The mechanics I had it at before are going to get an ear full because they said everything looked fine after they popped the cover... Hope this helps anyone with the same issue
The problem was so bad it has been suggested that I get a new carrier. So I decided to go with eaton e locker will we are in there.
H2oboy21 is offline
clunk , dana 44 , rear end , rear end noise , wheel bearing
Dana 30 spider gear slop??? Sneakboxer General Jeep & Off-Road Equipment 2 10-31-2012 12:54 PM
D35 Rear 1/4" of "axleshaft left-right slop" normal? Blk2kTj Engines & Drivetrain 8 01-16-2010 07:40 PM
Clunking coming from rear.. 98kkk Engines & Drivetrain 6 06-22-2006 08:57 PM
Rear Breaks (or axle?) Clunking agie Street Jeep Forum 19 05-28-2006 03:51 PM
slop in dana 44 hyperse7en Engines & Drivetrain 2 05-18-2006 01:52 AM
