dana 44 carrier series - JeepForum.com
post #1 of 5 Old 12-01-2012, 09:12 AM Thread Starter
brockj
I did some searching but didnt find what I was looking for. I have seen different carrier series for dana 44 but dont know what the difference is other than the break for gear ratios.
brockj is offline
post #2 of 5 Old 12-01-2012, 03:45 PM
ltrail
1984 XJ Cherokee
The flange that the ring gear bolts to is offset to accommodate the pinion and allow deeper gears. No real differences except gears that will fit them. Unless its a jk44, those I thought had different bearing or something silly.
What exactly are you looking for? The question is a bit vague.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #3 of 5 Old 12-01-2012, 06:23 PM
rjbruzan
Also different for the D44A in the Grand Cherokee and Isuzus.
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #4 of 5 Old 12-02-2012, 02:29 PM Thread Starter
brockj
I was just curious on the difference. I just bought and xj d44 and plan on putting a locker in it and didnt know if the difference carrier series made a differecent in what locker i needed. But if it has to do with how the ring gear bolts to it, then I assume there is just a high ratio locker, and low ratio locker, right?
brockj is offline
post #5 of 5 Old 12-02-2012, 06:11 PM
BlueRubiconrich
There is a break in the Dana 44 case
2:87-3:73
3:92-5:88
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
