dana 44 build up questions - JeepForum.com
post #1 of 19 Old 05-14-2012, 11:53 PM Thread Starter
chris56
I'm wanting to build up a dana 44 for the rear of my tj and have a lt of questions because this is my first time building an axle assembly.
Are all dana 44 housings equal?
What donor should i look for?
What all is needed in order for it to hook up to my tj it has a dana 35 now?
Ring and pinion, axles, locker, bearings, seals what else am i missing?
I appreciate any info, i tried the search function and couldn't find exactly what I was looking for. If you know a thread that answers these please point me the way.
I know its vague but this is my first axle build let alone jeep build but i've built several other vehicles
thanks
chris56 is offline
post #2 of 19 Old 05-14-2012, 11:58 PM
clg82
I pulled mine from a 2004 unlimited. Any dana 44 if i'm not mistaken from a TJ will work in your rear. The one I got bolted right up without any modifications and I also had the dana 35 previously. Do you have a lift on your jeep? Please fill out your jeep info as it will help us to diagnose what will work for you and what wont in the future...and welcome to the jeepforum. YOu want to find one with the same gear ratio that your TJ currently has, as you can't have two different gear sizes front and rear....
clg82 is offline
post #3 of 19 Old 05-15-2012, 12:00 PM Thread Starter
chris56
I appreciate the response I found one out of a 2003 they want 1300. Is that a reasonable price?
chris56 is offline
post #4 of 19 Old 05-15-2012, 02:47 PM
clg82
thats reasonable...I would check and see how the R&P looks before buying and does that include everything drum to drum....
clg82 is offline
post #5 of 19 Old 05-15-2012, 08:20 PM Thread Starter
chris56
I called on it and they said its got disc brakes. Is that right?
chris56 is offline
post #6 of 19 Old 05-18-2012, 07:53 PM
BlueRubiconrich
must be a Rubicon Dana 44 they have disc brakes.
You don't want a WJ Dana 44 weak housing aluminum center!
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #7 of 19 Old 05-18-2012, 08:26 PM
soonermatt
Well this isnt true. We could talk him into different tire sizes. That would compensate.
soonermatt is offline
post #8 of 19 Old 05-19-2012, 11:06 PM
fire2fire
Chris I don't know if you have already bought your 44 but I just came across front and rear w/5.89 gears for $200 total. You can ship to you for less then what your buying one.
Here is the Craigslist ad
http://reno.craigslist.org/pts/3015963187.html
fire2fire is offline
post #9 of 19 Old 05-19-2012, 11:35 PM Thread Starter
chris56
so the rubicon 44 will bolt right up? I just got to make sure the gear ratio is the same as my dana 30 front. Is there any modifications needed from going drum to disc brakes?
chris56 is offline
post #10 of 19 Old 05-19-2012, 11:37 PM Thread Starter
chris56
Good looking out man, but I believe that those are just the gears. I'm trying to buy a complete axle appreciate it though
chris56 is offline
post #11 of 19 Old 05-20-2012, 06:11 PM
Technohead
Rubicon's have 4.10 gears. Almost certainly, your current front axle does not. Best case scenario is to buy BOTH front and rear Rubicon axles. Don't forget to get whatever else is needed to make the lockers work. And while you are at it might as well grab the Rubicon t-case.
-Eric
Technohead is offline
post #12 of 19 Old 05-20-2012, 06:29 PM
clg82
How would different tire sizes compensate for not having the correct gearin in the front and rear axles? That is not true at all....you can NOT run two different gear sizes in the front and rear axles.
clg82 is offline
post #13 of 19 Old 05-20-2012, 06:30 PM
soonermatt
No it's true; just think it through a little. It's not logical for a jeep hence it was sarcasm. But it remains true.
post #14 of 19 Old 05-20-2012, 06:35 PM
clg82
it's hard to understand forum sarcasm, but now i do in fact get it....you win sir
clg82 is offline
post #15 of 19 Old 05-20-2012, 07:15 PM
MoabsForever
It could also be from a stock unlimited with disc brakes and 3.73. They came with D44's in the rear. Sorry, I didn't notice the year it was out of unlimited came out 2004.
MoabsForever is offline
control arm build questions jaspepp Fabrication Shop 10 04-28-2012 01:32 PM
Axle build/mod questions? tdkask Engines & Drivetrain 1 04-18-2012 04:56 AM
HP dana 30 build ryan6580 Fabrication Shop 0 01-13-2012 11:17 AM
JK Rubicon Dana 44 Build Paul08Wrangler Fabrication Shop 65 10-06-2010 07:37 PM
Dana 44 build Ratmeat Engines & Drivetrain 2 10-13-2008 02:22 PM
