dana 44 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > dana 44
Memorial Day Sale at Under Cover Fabworks! 15% Discount oNOTCH CUSTOMS - Max Clearance Fender FlaresIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 05-21-2006, 06:58 PM   #1
paraman72
paraman72's Avatar
dana 44
Does anyone know the spline count from the 44's that was in the jeep pickups?
85 CJ7 Build in progress, 258 with T-5 and dana 300.
Fiberglass tub Raptor lined interior, rustoleum lined the underside. Modified family roll bar from fender mounted rollbar. Full tie ins to the frame soon to come.
paraman72 is offline   Reply With Quote
Unread 05-21-2006, 07:27 PM   #2
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
pinion spline count?
Front axle? inner, outer?
Rear axle?
D44 = 30 spline on the shaft that enters the carrier.
HTH
-Tim GS-MW 2009 INFO
KD8EBC
'94 ZJ 5.2 LTD
Project TORTOISE Build-up thread
JCR Rock Sliders Ford Taurus E-fan Install Dana 20 Twin Stick
EMTimZJ is offline   Reply With Quote
Unread 05-22-2006, 12:03 PM   #3
paraman72
paraman72's Avatar
front and rear axles inner spline count...
Unread 05-22-2006, 05:47 PM   #4
jeepdaddy2000
1971 CJ5
19 for early(tapered ). 30 for late(flanged).
jeepdaddy2000 is offline   Reply With Quote
Unread 05-23-2006, 09:42 PM   #5
paraman72
paraman72's Avatar
So these are considered the weak dana 44's am I correct?
Unread 05-25-2006, 03:05 PM   #6
paraman72
paraman72's Avatar
In regards to the dana 44's which were the stronger ones?
Unread 05-26-2006, 12:21 AM   #7
jeepdaddy2000
1971 CJ5
The fine count on the later axles is a bit stronger due to their load bearing capabilities. I would be hard pressed to call the early models weak.
