Quantcast Dana 35 vs ford 7.5" - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Dana 35 vs ford 7.5"
Old 03-08-2010, 09:21 PM   #1
roccomonte
I got the dana 35 in my yj, and between the larger tires and engine swap, i blew out my rear end. Anyways I can get a ford 7.5 off a broncoII for free with matching gears and a limited slip w/ brand new clutches. Is this axle any stronger than the dana 35?
Drum to drum is 1/2" longer on the ford 7.5 both use drum brakes and i can get the driveshaft taken care of cheap.
roccomonte is offline   Reply With Quote
Old 03-09-2010, 12:38 AM   #2
RockCrawlerYJ
The ford 7.5 is probably better than the 35 but not worth the swap. Go find a ford 8.8 most of them are limited slip also. I dont know what engine you swapped into but anything bigger than a 4.0l with about 33 in tires would break that 7.5. An 8.8 is a great axle and you could probably pick one up for about $100.
RockCrawlerYJ is offline   Reply With Quote
Old 03-09-2010, 01:28 AM   #3
Technohead
Old school
Technohead's Avatar
Same ring gear diameter & nearly same axle strength (1.16"/27 spline D35 vs 1.20"/28 spline 7.5). Does not make sense to do this swap. You can probably find somebody that will give you a bolt-in D35 without too much effort.
Technohead is offline   Reply With Quote
Old 03-09-2010, 02:17 AM   #4
roccomonte
Yeah, but i'm in need of a rear axle immediatly... it has same gears with a brand new never ran limited slip, same lug pattern, its sittin on the side of my friends house and i already have the axle off the jeep. I'm gonna go ahead and do it tomorrow... at least i'll be going to a non c-clip axle those c-clips always scared me.
Also I put the engine from a 98 cherokee with a full obdII swap. so its probably only like 20 hp more than a YJ 4.0
Old 03-09-2010, 02:25 AM   #5
Boodyrider
Well, congrats, yet another guy asking for advice who doesn't want it.
8.8 swap is well documented beause it is a good swap. 7.5 is not, beause it's a bad idea for a number of reasons
Do as you will and don't bother asking what to do if you don't want advice
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline   Reply With Quote
Old 03-09-2010, 09:14 AM   #6
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
The Ford 7.5 is a c-clip axle unless someone has installed an aftermarket c-clip eliminator kit.
98 TJ
Wheelin98TJ is offline   Reply With Quote
Old 03-09-2010, 09:32 AM   #7
RockCrawlerYJ
I know crazy right. Why ask?
Old 03-09-2010, 11:43 AM   #8
roccomonte
You sure its c-clip? I'm looking at flanges on the axle tubes
Anyways I wasn't asking for advise on this swap, I was simpley asking for the strength difference. Obviously it's not a stout axle, but its slightly bigger than a d35, the drive shaft with this with work with an 8.8 further down the road...
I need the jeep up ASAP, its my DD and I can't be truant to class. Sorry if simple asking if its any stronger was a big deal.. I got the axle in in the time it woulda taken to change out gears and the driveline guy is changing out the yoke and re balancing right now.
Old 03-09-2010, 12:38 PM   #9
Wheelin98TJ
JEEP FREAK
Can you post a pic?
The flange you are looking at is probably for the brakes.
98 TJ
Old 03-10-2010, 06:32 PM   #10
roccomonte
I didnt get pictures during the swap, it's definatly not c-clip like the d35 there is flanges that hold the wheel bearing/axles in.
Anyways I found something odd about this axle, its 28 spline, but it has an 8.8" ring gear... I guess a few broncoII and rangers came with a hybrid of 7.5" tubes/axles with a 8.8" differential... I don't think I'll have a problem with this axle unless I twist off an axle shaft, but around here junkyards are full of fords so i'll see how it holds up.
Old 03-13-2010, 11:17 PM   #11
yellowford
That might be the weaker 8.8" that did come from the factory in the rangers they came with 28 spline shafts, its not really a hybrid of the 7.5 its just the smaller axle that came in rangers.
XJ hunting
yellowford is offline   Reply With Quote
Old 03-13-2010, 11:45 PM   #12
LJameson
"The 7.5-inch and 8.8-inch axles retain the axles using C-Clips. "
Ford Ranger Axles - The Ranger Station
2005 LJ- Mostly stock/ DD
2000 TJ- Slowly Rebuilding
1976 CJ7- 304/TH400 | 3" suspension | Warn 9.5ti |
LJameson is offline   Reply With Quote
Glock Forum
