Dana 35 Noise, when wheel pushed in/out - JeepForum.com
post #1 of 4 Old 07-31-2010, 07:18 AM Thread Starter
fec
I have a YJ Wrangler 1992 with Dana 35 C-Clips Rear axle. There is some noise when driving in terrain and the same noise is when I pull the rear wheels in and out. The axle hits the middle pin between the two axles. I have bought new C-Clips, but when messuring the new and old C-clips there are no difference in the thickness. The place in the axle where the C-clips are fitted is slightly thicker. 0,75mm (0,0295inch)more than the C-clips.
Is it the axles there ar worn?
The wheel bearings?
The surface the C-clips lean against?
Thanks,
Frank Christiansen
Denmark
fec is offline
post #2 of 4 Old 07-31-2010, 07:26 AM
1998zj
It is normal for there to be play. Every C clip vehicle I have owned had some.
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #3 of 4 Old 07-31-2010, 08:14 AM Thread Starter
fec
Thanks How Mouch
Thanks. Do you know if there is a limit to how mouch. Then sound has'nt been there before...
/Frank
fec is offline
post #4 of 4 Old 07-31-2010, 10:23 AM
1998zj
I don't know of a measurement, it feels like a lot when it moves in and out.
1998zj is offline
axle , dana 35 , wheel bearings , wrangler yj
rattling noise unless the clutch is pushed in blp5172 Engines & Drivetrain 21 04-17-2010 08:37 AM
Rebuilding Dana 30 CV Shaft? Chirping noise redhatman Engines & Drivetrain 1 01-01-2009 01:42 AM
Dana 35 is making noise... OneCleanYj Engines & Drivetrain 10 03-11-2007 06:39 PM
Radio only works when key pushed in Joezilla Audio, CB & Ham Radios, GPS, & Electrical 0 11-06-2006 11:24 AM
Rubber gasket pushed in on clutch/transmission jmsjeep Engines & Drivetrain 1 09-09-2003 06:42 PM
