Dana 35 Gear Change - JeepForum.com
post #1 of 7 Old 07-17-2007, 09:11 AM Thread Starter
2qk4u
Dana 35 Gear Change
Iam getting ready to change my stock gearing out to 410's. Does anyone have a good guide of instructions to help do this? im very mechanic oriented and would just like to have a little more backup on doing this.
also my carrier bearings only have probably 55,000 miles on them. would you all go ahead and replace them?
thanks
2qk4u is offline
post #2 of 7 Old 07-17-2007, 11:47 AM
miguelitojeep97
replace them all. better to spend the money now then get screwed on the trail!
ok a couple articles: the first one is very very detailed of everything you should need to know. good luck. I am currentyl having my gears re-done at a shop! cant wait for the results
http://www.pirate4x4.com/tech/billavista/Gear_Setup/
http://www.pirate4x4.com/tech/billav...structions.pdf
1997 TJ 4.0 5 spd. rock track 4:1, 3.5 inch Rock Krawler 5 inch stretch long arm, 35 inch MTRs, Warn 9k, D44/30 locked with 4:88s, Vanco BIG BRAKES!!and more...
miguelitojeep97 is offline
post #3 of 7 Old 07-17-2007, 12:28 PM Thread Starter
2qk4u
what are they charging you?
2qk4u is offline
post #4 of 7 Old 07-17-2007, 02:54 PM
miguelitojeep97
LOL well that, I am not suppose to tell anyone. I have a buddy that works for Offroad Werks in Ventura. I have given him plenty of business and have sent all my buddies to him. I also gave him a bunch of spair parts that I was ging to sell. Ill PM you the price. but he said normall he does re-gears for about $400 an axle. A little high on the price
post #5 of 7 Old 07-17-2007, 07:54 PM
blake989
$400 an axle total or labor only?
The YJ is no longer my DD. I have sacrificed all future retirement plans for jeep parts. I'm depending on social security!
blake989 is offline
post #6 of 7 Old 07-17-2007, 10:13 PM
miguelitojeep97
oh sorry just labor. I had all the parts b/c I was going to do it with a friend at his shop but he had been way too busy and wasnt going to be able to help by the time I needed.
post #7 of 7 Old 07-26-2007, 02:46 AM
80cj
80cj's Avatar
1980 CJ5
If you're very mechanically inclined, you should probably be able to do it provided you have access to all the required tools. Randy's Ring and Pinion web site used to have a good set of instructions. I think the most important thing is recognizing patterns and knowing how to adjust to correct. I taught myself and have not had to re- do any installations. No noisy gears and I've done 10 so far. The first couple took a lot of time but once I found out what to adjust to get a good pattern, the rest was easy. Patience is a must have. Buy good gears. I highly recommend Yukon. Their gears pattern very well and their install kits are excellent. A lousy gear set that doesn't pattern well just makes the job more confusing for the beginner.
80cj is offline
1st gear change for T-18 jjlove Engines & Drivetrain 8 08-29-2007 05:49 AM
gear change on 33's? urwaker Tires & Wheels 6 04-26-2005 05:46 PM
whats involved in gear change supersly_jones Engines & Drivetrain 7 02-25-2005 07:47 AM
tj gear change bnewsom General Jeep & Off-Road Equipment 4 08-22-2003 11:35 PM
Gear change but 2 what? TotalJeep General Jeep & Off-Road Equipment 3 06-26-2003 07:43 PM
