Dana 35 differential gear a little chewed up (some metal shavings inside). - JeepForum.com
post #1 of 4 Old 10-03-2012, 04:23 PM Thread Starter
srm1982
So I changed my differential fluid again after noticing a leak from what appeared to be the pinion seal failing. I noticed some metal shavings inside the differential and also that the oil seemed silvery. After I took off the differential cover I noticed one of the smaller gears (one of the four grouped together next to the large one, see picture), seemed to have some small chunks missing; it also has some play when I moved it. There doesn't seem to be any kind of performance issues as of yet though. I cleaned it out with brake cleaner and got all the metal shavings out, and replaced the oil and sealed her up. What do you think, is it necessary to replace that gear?
srm1982 is offline
post #2 of 4 Old 10-03-2012, 05:37 PM
wgirvine
1992 XJ Cherokee
Yep. And all the other gears and bearings, too. Keep in mind that I go so far out into the Mojave Desert that if I broke down, they would never find my body. So I tend to go a little overboard on repairs and maintenance. If you are just thrashing around in the back yard, you might decide you can live with the inconvenience of a breakdown.
But if that were mine? Oh yeah, I'd rebuild the entire axle assembly.
The road goes on forever, the party never ends....
wgirvine is offline
post #3 of 4 Old 10-03-2012, 07:00 PM
BlueRubiconrich
Time for a Dana 44.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #4 of 4 Old 10-09-2012, 03:56 AM Thread Starter
srm1982
Thanks for the advice. I am looking into replacing the spider gears. When I replaced the pinion seal I checked out the bearings and they seemed fine. I've spent the last couple of hours looking into the different options with differentials and gearing ratios... but it seems for the time being a 45 minute gear replacement would set my mind at ease up in the mountains looking for Bambi's dad.
srm1982 is offline
