Dana 35 Beef Up - JeepForum.com
post #1 of 11 Old 05-17-2006, 01:35 PM Thread Starter
00Vert
Dana 35 Beef Up
I looked into swapping the complete 8.8 Explorer axle and decided against it. Too much hastle for me. What I am wondering is, if there are stronger than stock bolt in components which would allow me to retain the stock Dana 35 housing and brakes in my YJ. Looking for stronger axles, posi, etc. What stuff do you recommend to strenghten the drive train for light to medium off road work. I don't care, or want, disc brakes in the rear. Thanks, Phil
00Vert is offline
post #2 of 11 Old 05-17-2006, 01:59 PM
Johnny World
Johnny World's Avatar
There's a link in the YJ FAQ about some Superior Super 35 kit which comes with I believe the parts you are looking for.
'02 WJ, Laredo Special Edition, 4.0L I6
Johnny World is offline
post #3 of 11 Old 05-17-2006, 04:45 PM
grandman97
grandman97's Avatar
if u plan on running anything more than 33s dont waste your money on trying to strengthen the d35... get a d44 or an 8.8... u can usually find them with all the brackets and everything done so u just have to bolt them in
grandman97 is offline
post #4 of 11 Old 05-17-2006, 09:23 PM Thread Starter
00Vert
[QUOTE=grandman97]if u plan on running anything more than 33s dont waste your money on trying to strengthen the d35...
Only running 31s and don't plan to go bigger.
Phil
00Vert is offline
post #5 of 11 Old 05-17-2006, 10:07 PM
Skyline
Skyline's Avatar
I gather you are talking about finding an axle that someone else has already set up for a Jeep. But aren't you talking about a CJ,YJ etc? I have a ZJ. What kind of vehicle would be an appropriate donor?
'96 Green ZJ Laredo V8; 4.5" SA lift, RE 4.5 Springs JKS CA's, MX-6 Shocks, OME SS, Kevins TB Conversion, JKS rear TB, JKS Discos, Kevins Sliders, 16x8 Pro Comp Wheels, Dunlop Mud Rovers (33's)
Skyline is offline
post #6 of 11 Old 05-18-2006, 04:05 AM
92 Green YJ
92 Green YJ's Avatar
[QUOTE=00Vert]
Phil
if thats the case, then honestly, you shouldn't have to do anything to the D35. running it open it will hold up to 33s for a while. but if you go to 35s, forget it. you should be able to lock it and get away on 31s without too much trouble. If you want the extra piece of mind, look into the Superior Super 35 kit. but for what its gonna cost you to get it and get it installed, you may as well just do the 8.8
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #7 of 11 Old 05-18-2006, 08:11 AM
GrimJeeper91
GrimJeeper91's Avatar
I've been running my D35 locked for 6 years and wheel it pretty hard. I decided to stay with the D35 until it breaks. You drive it and right and it will last. EVERY D35 I have seen break on the trail was the result of driver error. You should be fine with the 31's.
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline
post #8 of 11 Old 05-18-2006, 01:36 PM
92 Green YJ
mine never broke on the trail, it crapped out on the street. and I was running it open on 35s.
My
post #9 of 11 Old 05-18-2006, 02:18 PM
frankiefire702
You can pick up a super/grande/ultimate 35 kit for around $800. I've been running that kit for almost two years and I don't consider myself easy on my junk.
06 tj locked on 36's.
frankiefire702 is offline
post #10 of 11 Old 01-18-2011, 09:57 AM
23ethan23
frankiefire702 you have been running the super kit for two years with 36's !
Red 97 tj 4.5" rubicon express lift 2 inch body, 5spd sye and tomwoods
23ethan23 is offline
post #11 of 11 Old 02-11-2011, 02:39 AM
VanDahmage
Curious with what you ended up doing?...I read so many posts don't have a resolve. We have a d35 with a 3.08 gear and a bent outer shaft. Someone in a saturn went under her and ran into the tire. We were hoping the U bolts just slid but no such luck. She's on blocks until we can find a solution that doesn't include changing the front gears..So, I'm interested in what you came up with.
VanDahmage is offline
Dana 30 Beef Up BlazerJeepCombo Engines & Drivetrain 0 09-27-2009 09:19 PM
Cost effective. Is it worth it to beef up and rebuild my 44re, or buy a 46re? redhatman Engines & Drivetrain 0 08-25-2009 06:17 PM
8.8 Limited slip works like crap. Anyone beef theirs up? TexanTJ Engines & Drivetrain 1 08-14-2009 06:20 AM
DANA 30 outers on DANA 44 front axle-- with a twist IN8LYJP Engines & Drivetrain 1 07-08-2009 05:40 AM
How to beef up frame ??? 84 cj7 Jzilla Cheap Tricks & Fixes 0 11-27-2008 09:20 PM
