Dana 30 ZJ vs XJ - JeepForum.com
post #1 of 10 Old 12-27-2012, 02:16 PM Thread Starter
Lordofwar1441
1994 ZJ
Dana 30 ZJ vs XJ
I have a 94 ZJ with U-joints. Now most ZJs have CV joints from all the other forums I read. Are these U-joints I have the same as in a XJ of similar year?
Lordofwar1441 is offline
post #2 of 10 Old 12-28-2012, 04:16 PM
95zjman86
I would say probably. You want the better 760 u-joint. What transfer case do you have? I bet you have the 242 case?
95 zj iron rock offroad 7 inch long arm front 242 swap 4.56 gears ford 8.8 with yukon grizzly bfg km2's 35 inch warn m8000
95zjman86 is offline
post #3 of 10 Old 12-28-2012, 04:30 PM Thread Starter
Lordofwar1441
1994 ZJ
Nope it's a 231
post #4 of 10 Old 12-30-2012, 01:15 AM Thread Starter
Lordofwar1441
1994 ZJ
They look like this
post #5 of 10 Old 12-30-2012, 01:20 AM
BriansCJ
1994 XJ Cherokee
They should be the bigger style, with abs.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #6 of 10 Old 12-30-2012, 01:22 AM Thread Starter
Lordofwar1441
1994 ZJ
So same as the XJ U-joints?
post #7 of 10 Old 12-30-2012, 02:01 AM
BriansCJ
1994 XJ Cherokee
A 94 XJ will have 2 u joint sizes.
260x and 297x(w/ ABS).
- Slow
BriansCJ is offline
post #8 of 10 Old 12-30-2012, 02:25 AM Thread Starter
Lordofwar1441
1994 ZJ
So I'm assuming the bigger number the bigger the U-joint?
post #9 of 10 Old 12-30-2012, 02:53 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Yes. The 95+ and abs Cherokees had the 297 ujoints which are the same size as the 760 joints found in the chromoly kits. The 260's aren't terrible if they're maintained. Most of the time if you have good ujoints regardless of size, the shaft will snap first. Unless you have a locked front and and like doing tight donuts in dry parking lots in 4 low. Then you will go through them like toilet paper.
Luck Favours The Prepared
Anticanman is offline
post #10 of 10 Old 12-30-2012, 08:28 AM Thread Starter
Lordofwar1441
1994 ZJ
Thank you that is what I wanted to know
