Dana 30/35... Rebuild or upgrade? - JeepForum.com
post #1 of 7 Old 12-07-2013, 09:52 PM Thread Starter
trasnow
88' YJ with stock axles, time to change gears, but I'm not sure if I should rebuild the Dana's or upgrade to something better...
trasnow is offline
post #2 of 7 Old 12-08-2013, 08:42 AM
biffgnar
biffgnar's Avatar
Your profile is not filled out and you've told us very little about your jeep or what type of wheeling you do. How are we supposed to answer?
Romney in 2020!
biffgnar is offline
post #3 of 7 Old 12-09-2013, 12:01 PM
BlueRubiconrich
Replace the Rear With a Ford 8.8
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #4 of 7 Old 12-09-2013, 12:35 PM
BEETROOT
I recommend Dana 60 and a 14 bolt.
BEETROOT is offline
post #5 of 7 Old 12-09-2013, 04:21 PM
BlueRubiconrich
that's over kill. 1 you could regear the 30 and dump the 35 for a 8.8
2 you could use the right year Waggy front axle and then a waggy rear end.
post #6 of 7 Old 12-09-2013, 05:33 PM
Spud100
Depends on your use and how much you want to spend. You said you want to regear but give no indication how much or what type of off roading, if any, you do. If it's used only on the street and perhaps light off roading, stick with what you have and save your money. If you moderate to extreme off road and you pound the crap out of it, you probably should invest in a better set-up.
Spud100 is offline
post #7 of 7 Old 12-09-2013, 05:59 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
option #2, That is what I did, cost me a whopping $165 for everything.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
