Dana 20 T-Case leak - JeepForum.com
post #1 of 10 Old 03-12-2012, 08:53 PM Thread Starter
Blacky15
Dana 20 T-Case leak
I have a AMC 360 bolted to a TH400 and then a Dana 20 Tcase. My tranny was rebuilt a year ago and I rebuilt the Tcase myself. I am having my Tcase fill full of tranny fluid and then my tranny will stop engaging until I put more fluid in. Question is does the Dana 20 from a IH Scout require gear lube or does it use tranny fluid? And then how hard it is to replace the seals in the tranny and Tcase to stop this pain in my ars?
Thanks for the help!
Blacky15 is offline
post #2 of 10 Old 03-12-2012, 11:47 PM
mmerlinn
Huh? The transmission fluid is separate from the transfer case fluid so HOW does filling the transfer case have any effect on how the transmission shifts?
mmerlinn is offline
post #3 of 10 Old 03-13-2012, 12:17 AM
jnicewan
I think he is saying the TH400 is leaking ATF into the Dana 20.
Anyway the dana 20 takes gear oil. I am not too familiar with the TH400/D20 combo so I am not sure which one and maybe both have had a seal failure. A lot of the time the only seal is on the T-case input shaft, but some trannys have an output seal too. Whichever it is, you can replace the seals after you seperate the case from the trans.
jnicewan is offline
post #4 of 10 Old 03-15-2012, 05:12 PM Thread Starter
Blacky15
Thank you jnicewan you are correct. I have having my tranny fluid flow into my dana 20 transfer case and then out the output shaft of the transfercase. Does anyone know if the TH400 has a rear seal or if it is just the Dana 20 input shaft seal that needs to be replaced??
Blacky15 is offline
post #5 of 10 Old 03-27-2012, 11:10 PM
mmerlinn
No rear seal on a 400 transmission.
mmerlinn is offline
post #6 of 10 Old 03-28-2012, 09:47 AM Thread Starter
Blacky15
I pulled the two units apart and there is no rear seal on the th400. mmerlinn is correct. What I did find was that there was no O-Ring on the tailshalf of the th400. It the shaft that slides into the Texas style adaptor bracket. Not sure if the o-ring tore or what but i couldnt find it anywhere.
After installing the new o-ring I beleive I now have a non-laeking th400/dana 20 combo.
Thanks everyone for the help. Gotta love this site!!
Blacky15 is offline
post #7 of 10 Old 04-04-2012, 09:57 PM
RockHands
1987 YJ Wrangler
Was it a "big" leak? I am trying to run down a small leak at the interface of my th400 and Stak 3-speed. Just curious before I try to pull it all apart.
RockHands is offline
post #8 of 10 Old 04-05-2012, 12:32 AM Thread Starter
Blacky15
It's wasn't big like all over the place it would only leak when i was driving and there pressure would push the fluid into the transfercase and out the overkill vents. But since the oring went on I'm drip free. Real easy fix too
Blacky15 is offline
post #9 of 10 Old 04-05-2012, 08:59 PM
RockHands
1987 YJ Wrangler
Drop the T-case and there it was?
post #10 of 10 Old 04-06-2012, 11:10 AM Thread Starter
Blacky15
The missing O-ring on the tailshaft of the th400. There is a groove ground down spot for it midshalf. If you're looking for it you cant miss it.
Blacky15 is offline
Dana 20 T150 Leak After Reinstall bcp_40 Engines & Drivetrain 0 08-22-2011 08:38 PM
Dana 20 T-case from what? elizabeth968 Engines & Drivetrain 6 04-23-2011 06:23 PM
Swapping a dana 20 transfer case for a dana 18 masimpson48 Engines & Drivetrain 2 12-12-2009 03:05 PM
Dana 44 seal leak? unlimiter Tires & Wheels 2 04-28-2008 09:45 PM
T case drop cause oil leak? mflave007 Tires & Wheels 3 03-23-2006 08:46 PM
