D60 gears - JeepForum.com
post #1 of 9 Old 02-06-2006, 10:07 AM Thread Starter
Jeep wanna Be
D60 gears
Anybody know what ratio gears are availible for a D60 ?
Jeep wanna Be is offline
post #2 of 9 Old 02-06-2006, 06:02 PM
350Jeep
I believe Dana 60s can use pretty much any ratio up to 5.38's. What ratio are you looking for? What setup are you running?
'92 Wrangler, 350ci Chevy w/ Holley Truck Avenger carb, B-W WC T4, NP231 w/ JB conversions SYE, Ford 8.8 rearend w/ ARB, Dana 44 front w/ ARB, 4.10's, Rubicon Express XD 4.5" lift, 35" MT/R's on 15"x8" American Racing wheels, 6" Bushwacker cut-out TJ-style fender flares, custom polished aluminum dash w/ full set of Autometer Ultra-Lite gauges, Warn HS9500i winch, Big Daddy Step Rock Rails, custom, self-made rear bumper
350Jeep is offline
post #3 of 9 Old 02-06-2006, 10:59 PM Thread Starter
Jeep wanna Be
I am currently in the planning stages. I am thinking about running D60 with 44 inch tires.
post #4 of 9 Old 02-07-2006, 11:30 AM
BigJeepJay
BigJeepJay's Avatar
Nope, you can also get 6.17 and 7.17 gears for a D60 although anything over 5.38I beleive is considered industrial and not as quiet.
I've seen 44's run on a Jeep with gearing from 4.56 up but it all depends on what engine/tranny/TC you are going to use...
Pics...
TJ Stretch Thread...
BigJeepJay is offline
post #5 of 9 Old 02-07-2006, 02:51 PM Thread Starter
Jeep wanna Be
I think I need something around 6.0:1. Ahh this is a trail rig noise is ok.
post #6 of 9 Old 02-08-2006, 10:55 PM
drewsjeep
The spicer book I have shows a 5.86 also. It really depends on what front end you use. If you use a ford high pinion you are limited to 5.38 according to this book. There may be some lower gears for them from another company.
drewsjeep is offline
post #7 of 9 Old 02-09-2006, 09:24 PM Thread Starter
Jeep wanna Be
I really think I will go with dynatrac axels. 5.86 might be close enough.
post #8 of 9 Old 02-10-2006, 10:36 AM
BigJeepJay
BigJeepJay's Avatar
What size tires are you going to run because 5.86 gearing is good for 42"+ Tires. Why not run a lower and more standard gear and get an Atlass II or Tera-Low for a better low range output?
Pics...
post #9 of 9 Old 02-11-2006, 01:22 PM Thread Starter
Jeep wanna Be
I am thinking about 44" tires 5.86's would do the job then.
Replacing JK X gears with Rubicon JK gears kb8687 Engines & Drivetrain 0 09-22-2008 12:46 AM
Gears?! NotoriousBLE Engines & Drivetrain 5 06-11-2008 07:27 PM
I Need New Gears johndsandy General Jeep & Off-Road Equipment 2 10-13-2005 12:38 PM
Which gears do I get??? mike481 General Jeep & Off-Road Equipment 6 10-03-2005 01:39 PM
4.10 or 4.56 gears which for this rig? Flyingbrass General Jeep & Off-Road Equipment 22 09-12-2005 05:35 AM
