D35 Leaking only downhill. - JeepForum.com
post #1 of 8 Old 04-27-2013, 07:32 PM Thread Starter
Shoelessboi
As the title says. My d35 is leaking gear oil when it's downhill/slanted. Coming from the yoke on the axle. People in pepboys, napa And ghetto zone couldn't figure out what it is. Any help would be appreciated. I know it's a seal. But which. I also have the ubolt style yoke on it for the Tom woods driveshaft.
Originally Posted by dillonjm View Post
:The fact you even asked this question makes me want to punch myself in the face.
1991 Jeep Yj. 4cyl. 33x13.50x15 TSL Thornbirds, Super Wader Snorkel, 4" Rough Country Suspension Lift, Uniden Pro520xl Cb, 1000W Amp, 12" Rockford Fosgate P2 Sub.
Shoelessboi is offline
post #2 of 8 Old 04-27-2013, 11:43 PM
AKjeff
1974 CJ5
Sounds like you need a pinion seal.
Did the leak start right after you installed the new yoke?
Does Tom Woods mention anything about the yoke working with the factory pinion seal?
You'd think it would but you never know.
AKjeff is offline
post #3 of 8 Old 04-28-2013, 07:52 AM
Evildriver-3
When you're parked down hill the oil would run to the front of the diff so it would show a bad pin seal.
If it happened with the new yoke maybe the yoke is slightly smaller on the gh surface
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
post #4 of 8 Old 04-28-2013, 08:33 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Inner axle seal.
jeepdaddy2000 is offline
post #5 of 8 Old 04-28-2013, 08:39 AM
AKjeff
1974 CJ5
Thanks for the highlight jeepdaddy I didn't understand he meant the axle shaft.
AKjeff is offline
post #6 of 8 Old 04-29-2013, 05:27 PM
BlueRubiconrich
replace your whole Dana 35 with a real axle that will help
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #7 of 8 Old 04-30-2013, 07:52 AM
Evildriver-3
Inner axle seal.
There is no yoke on a axle on any D-35 other then the pin yoke.
Inner seal is am description for the seal used at front diffs because of axle wobbling from joints oscillating in turns that would shorten the seal life in that location, and because you need to go inside to change that seal.
D-35's have a axle seal at the outside of the bearing usually pressed into the housing which would be the axle seal.
If he said when parked off camber it leaked out of the drivers or passenger side Axle then i would agree he needs a axle seal and not a inner axle seal, but still a pinion seal.
The correct description is a pinion yoke seal
]=Supershafts=[
post #8 of 8 Old 04-30-2013, 10:19 PM
jeepdaddy2000
1971 CJ5
You are correct. I assumed that the use of the word "yoke" he was referring to the front axle U joint and simply mis-labeled it as a 35.
That is what I get for thinking......
