D35 to D60 swap info? - Page 2 - JeepForum.com
post #16 of 22 Old 10-30-2012, 06:24 PM
SLADE
78/79 Bronco and F150 Dana 44's have cast chunks and you should avoid them unless you plan to run the Ford radius arm suspension.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #17 of 22 Old 10-31-2012, 02:58 PM
Bama_WJ
Bama_WJ's Avatar
Check out late model Super Duty trucks. The Sterling 10.25/10.5 is comparable to the 14B without the low hanging diff. And there is no shortage of F-250/350 trucks around...
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #18 of 22 Old 11-01-2012, 02:55 PM
KingtheZJ
to me, the 14 bolt is superior because it has:
double shear pinion
stronger 2 piece carrier
easier gear setup
easy to install pinion guard (necessary for a LP housing that has a crush sleeve)
i don't have hard numbers, but i'd be surprised if it has any more clearance than a 14b that was shaved for a Barnes4wd cover.
i will agree that the 10.25 and 14b are comparable in price. but the 10.5 with its dick brakes, usually runs for a little more.
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #19 of 22 Old 11-02-2012, 08:51 AM Thread Starter
jeepmike4x4
You guys are throwing out great ideas. I really appreciate it. My wife and I currently rent a house from a friend and are looking into buying a house soon. The Jeep will probably go on the back burner for a bit. But it gives me more time to research!
jeepmike4x4 is offline
post #20 of 22 Old 11-02-2012, 09:07 AM Thread Starter
jeepmike4x4
Hey KingtheZJ,
I checked out the rear bumper you built. That thing looks great. I'm looking to do one for mine soon. I'm a certified welder and michinist by trade. That thing looks really clean. Good job for a first timer!! If you get a chance I posted a front bumper build in the "Fabrication shop"
It's the thread #15 from the top! Check it out!!
post #21 of 22 Old 11-02-2012, 10:08 AM
rjbruzan
Take a look at this
http://eastcoastgearsupply.com/i-686...4-5-5x5-5.html
Then finish it off your self
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #22 of 22 Old 11-02-2012, 10:27 AM
KingtheZJ
Originally Posted by rjbruzan View Post
Take a look at this
Ron
and spend 3-4 times more than i will on a 14b?
no thanks
'88 XJ
