Quantcast D35 axle swap - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > D35 axle swap
GR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!
Old 12-06-2007, 02:43 PM   #1
TJ Clay
D35 axle swap
OK so i know the D35 is short lived in TJs that see any hard 4wheelin. What i'm wondering is how hard is it to do a field swap if one breaks while on the trail. What tools, spare parts and anything should i have with me. It might be awhile before i round up the cash for D44
TJ Clay is offline   Reply With Quote
Old 12-06-2007, 10:28 PM   #2
IGotADisneyJeep
Its best to bring along spare axle shafts so, you can replace them.
To fix it you'll need:
Strong jack stands 6 tons if possible
Hi Lift
Your tools
A strong magnet
A pole to poke inside the axle tube to get the metal pieces that broke or stuck inside
Extra diff. fluid
Plastic bag to drain the old diff. fluid
Picks to pull the C-Clip out
Needle nose to pull things out
Hammer and screw driver to open the diff cover
Black RTV for your new gasket seal
A blade scraper to remove the old diff gasket
Cans of break fluid to clean the inside of the axle tube and diff case
A roll of plastic so, You can lay on when you are on the ground
Garbage bags for your garbage
These are most I can think of but, I am sure there maybe some I missed.
If the time ever comes and you do break an axle shaft try to work neat and be organized it will make things a bit more easy to get the job done. Also,
make sure you secure your jeep so it will not move or fall when the jeep is up in the air a few feet. Work on a flat area and think safety at all times.
Good Luck and I hope this helped a bit.
I'm Michael, Founder of: "Jeeps Gone Wild™"
www.JeepsGoneWild.org
IGotADisneyJeep is offline   Reply With Quote
Glock Forum
