Cylinder head - JeepForum.com
post #1 of 3 Old 03-03-2002, 07:58 PM Thread Starter
Josh
Cylinder head
I was wondering if anyone here has put the 4.0 cylinder head onto a 4.2 motor and if so, how much power did you pick up, and what is the cost the head whether it was new or used, thanks guys
1987 Wrangler, mods...currently torn apart, working on new motor, SOA, Dana 300, d44 front, ford 9 rear
Josh is offline
post #2 of 3 Old 03-04-2002, 03:58 PM
sixpak
1972 CJ5
Hello, In my opinion it is the single best mod you can do for the 4.2. You will hear that it is not possible without filling the water jacket holes in the head. I would suggest putting it on using the STOCK 4.0 head gasket and giving it a whirl. Chances are that it will be fine as this is what I did with my sand drag motor and it worked fine for two seasons until I built my own stroker motor using the 4.0 block. It is possible that after insalling the head that it may leak between the head and block and if so it will be noticable during filling the motor will antifreeze or the first test drive usually. I also suggest getting an aftermarket cam based on your intended use for the motor. Don't forget to pick up the intake and exhaust manifolds too. Make your own adapter for the injected intake, plug the injector holes and happy motoring! I did this mod back in 89 or so and the race car picked up 3 tenths on a 300 foot sand drag track with no other changes.
sixpak is offline
post #3 of 3 Old 03-04-2002, 06:46 PM Thread Starter
Josh
Thanks for the reply, I what about putting it on a block out of a CJ Jeep, as I hear the motors are slightly different, this will be a daily driver, anything I can do about the water jackets? thanks again
Josh is offline
Question about a 4 cylinder head gasket, please advise djkbooth Engines & Drivetrain 3 12-10-2009 09:04 AM
4.0 cylinder head question - valves bwiencek Engines & Drivetrain 0 01-12-2007 04:06 PM
2000 4.0L cracked cylinder head sgaenzler Engines & Drivetrain 3 10-24-2006 06:41 AM
An header form HESCO, its a inline six cylinder aluminum head, arieljeep Engines & Drivetrain 1 08-09-2005 04:03 PM
aftermarket cylinder head james985 Engines & Drivetrain 6 02-24-2005 01:40 PM
