"CV Axles" - JeepForum.com
post #1 of 6 Old 09-17-2013, 11:27 AM Thread Starter
Awesome
"CV Axles"
http://www.quadratec.com/products/52400_1904.htm
I have a question about those things: why would they be any stronger than a U-joint axle? It is my understanding that a CV joint still uses U-joints. So wouldn't that just be a regular U-joint axle with a cover around the U-joint?
100 Characters is not enough to have an interesting/relevant signature.
Awesome is offline
post #2 of 6 Old 09-17-2013, 11:30 AM
IH8PEPL
Right from the page you linked:
No U joints... They basically spread out the load over a greater area, making them much stronger and reliable. You can read the little captions on the photo that explain why RCV are better than standard U joints. I run RCV shafts and love them. They work expecially well with lockers when the wheels are at full turn. Oh and this too: "backed with a "No Questions Asked" limited lifetime warranty."
IH8PEPL is offline
post #3 of 6 Old 09-17-2013, 11:36 AM
Evildriver-3
CV is used to mean constant velocity joint, which all joints are so cv is used as another meaning for u-joints.
But we use cv to describe joints that run larger angles such as dual cv's or joints used in a h-yoke, the above picture we call rzeppa's since it is a rzeappa joint, however it is another form of a constant velocity joint.
The rzeppa design is better
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
post #4 of 6 Old 09-17-2013, 11:42 AM Thread Starter
Awesome
Okay, I get it now. I didn't see that image on the Quadratec page. Ball bearing design is superior....... but it makes me wonder how well it handles dust, dirt and mud. I can't imagine the polyurethane cover keeps it 100% sealed.
Does their "limited" lifetime warranty allow you to send broken shafts in for free replacements?
Awesome is offline
post #5 of 6 Old 09-17-2013, 11:55 AM
IH8PEPL
The boots are the hardest part to install. It takes a lot of strenght to put them on - if I remember right, the instructions mention having someone help you burp air out of the boot cover with a flat head screw driver while you push it down over the rcv end - that should give you an idea of how good the seal is. Plus they're packed with grease. Probably sealed better than any rubber CV joint boot on the market. Ive personally gone through sand/mud/deep water with zero issues.
Unless its changed since I purchased them, the warranty is: “You break it and we’ll replace it”.
Their web site covers just about any question you may have.
http://www.rcvperformance.com/
IH8PEPL is offline
post #6 of 6 Old 09-17-2013, 11:57 AM
vadslram
They broke? Well I guess you reached the limit, sorry
vadslram is offline
