Cutting out - JeepForum.com
post #1 of 11 Old 08-23-2012, 04:48 PM Thread Starter
DALY
1982 CJ5
Cutting out
I have a CJ5, 4 cylinder that "cuts out" while I am driving down the road. It doesnt die, just "coughs" as my wife puts it....any thoughts or ideas?
We are new to jeeping and just went through emissions for the second time, first time failed the pressure test. I changed a few hoses and got a passing grade. Ready for the road but would like to figure out the issue of cutting out. Doesn't do it all the time, mostly intermittent.
Any ideas?
Thanks!
Daly
DALY is offline
post #2 of 11 Old 08-23-2012, 11:49 PM
Wrenchtwister13
Sounds like it might be running out of fuel do you still have the emissions report tell me the readings could also be in the distributor is the timing set correctly when was the last tune up and what was done to it check the fuel filter
Wrenchtwister13 is offline
post #3 of 11 Old 08-25-2012, 06:17 PM Thread Starter
DALY
1982 CJ5
Thanks for the reply.
The emissions results were;
hydrocarbons 1.46
Carbon monoxide 22.61
NOX 2.96
Not sure on the tuneup, or the distributor. The kids have had it for awhile.
Seems to idle fine, how would I check the fuel filiter?
Thanks!
Daly
DALY is offline
post #4 of 11 Old 08-25-2012, 07:32 PM
Wrenchtwister13
I would start with a tune up replace the spark plugs wires,spark plugs, distributor cap,rotor,pcv valve,fuel filter, check the timing, adjust the carb to start with the carbon monoxide is really high its actually over fueling the carb might need a rebuild or you have internal eng problems also if you have a compression tester check the compression it kinda seems like camshaft is going flat I would start with a compression test first before anyrhing then let me know what the readings are
post #5 of 11 Old 08-26-2012, 12:39 PM Thread Starter
DALY
1982 CJ5
Thanks for the info! I will start with the plugs, wires, distributor cap, rotor and PCV valve and go from there.
Thanks again!
Daly
DALY is offline
post #6 of 11 Old 08-29-2012, 10:12 PM Thread Starter
DALY
1982 CJ5
I changhed the distributor cap, rotor, and PCV valve and thought I had it fixed. foound a post on the distributor cap broken off. Ran it for about 20 miles total the last few days and it started to do the same thing. I dont have a timing light or a compression tester, the plugs and wires are almost new. The carb I was told was recently rebuilt. I will look for the fuel filter, didnt check that as of yet...
Still trying to figure this out.
Thanks Daly
DALY is offline
post #7 of 11 Old 08-29-2012, 10:22 PM
Wrenchtwister13
You can rent a compression tester and timing light from a local parts house if you buy alot of stuff from them they may just let you use it
post #8 of 11 Old 08-29-2012, 10:23 PM
Wrenchtwister13
How about the spark plugs and wires
post #9 of 11 Old 08-29-2012, 10:24 PM
Wrenchtwister13
The plug could be fouled out on the cylinder with a broken dist tower
post #10 of 11 Old 08-30-2012, 06:56 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
And the wires could be cracked internally from being handled during the dizzy cap replacement. You want reliability? Don't cheap out. Replace the fuel filter, too.
cruiser54 is offline
post #11 of 11 Old 09-09-2012, 05:25 PM Thread Starter
DALY
1982 CJ5
Well I think I, we, figured it out. Remember I havent with mechanical stuff for many years. I am a Paramedic, not a mechanic...haha! My neighbor has a friend who is a "jeep expert", so he came over and bottom line was I would exchange the carb since he felt it was a fuel issue. My neighbor, who is as much of a mechanic as myself, asked about the fuel filter so we checked the fuel filter and it was plugged, $1.50 for a filter, (I got a spare just in case), put it in and runs like a champ! Go figure...
I appreciate everyone's advice. I look forward to tinkering with this CJ5 for a long time...
Thanks!
Daly
DALY is offline
What does everyone use for cutting? Zeros Fabrication Shop 10 08-15-2012 04:55 PM
cutting off?? blackwidow98 Engines & Drivetrain 1 07-01-2012 07:01 PM
Arc Cutting? RedMountainYJ Fabrication Shop 18 03-19-2008 10:04 PM
Need Help Cutting??????? Stan99 Fabrication Shop 4 02-22-2008 11:55 PM
Cutting a jam nut HMTwin Fabrication Shop 1 08-17-2006 12:08 PM
