Cranking/Starting Problem - JeepForum.com
post #1 of 4 Old 04-29-2012, 11:10 AM Thread Starter
chadandloren
I have a 2001 Jeep Grand Cherokee 4x4 with 4.7L. I am having problems getting my Jeep to crank.
Details: The jeep will crank eventually and once running, it runs until I turn it off or run out of gas. The jeep runs great once its running.
Ways to get it to crank: 1. try iginition for about 1-2 minutes with pumping accelorator. 2. turn key one time and then off and turn key again will start vehicle on second time always. 3. leave key on for about 20-30 seconds and eventually cranks.
Things replaced: spark plugs and injectors.
Any ideas on what could be the problem and how to go about fixing it?
chadandloren is offline
post #2 of 4 Old 04-30-2012, 06:33 PM
neonhomer
First off, "pumping" the gas pedal does nothing on a fuel injected vehicle. I take that back, if you hold it to the floor, it puts the PCM into a "fuel clearing mode". IIRC....
Almost sounds like maybe you are having a fuel supply problem. Once the vehicle runs, can you shut it off and be able to start it back up within a couple of minutes?
NeonHomer
Mid-Florida Jeep Club - Member
1996 Jeep Grand Cherokee, 4.0L/42RE/242 - Rebuilt motor w/ Comp cam (4/12), 3.5" Junkyard F>R lift, 31x10.5.x15 M/T's, Spartan Locked D44a, TC & tank skids, F&R adj trackbars, V8 steering arms
Galaxy DX99V CB, 102" SS Whip, Yaesu FT-2900R 2m, Larsen 1/4w mag mount, Sony HU, Massive 3way - F Door, Pioneer 3way - R Doors, MB Quart ONX304 Subs (x2), Lanzar 1600w amp.
"No Matter Where You Go... There You Are."
"Oh me oh my a lovely day is dawning. Oh what a joy I didn't wake up dead. So I can go to work and then resume my yawning, and get my sleep on site instead of in my bed" - Daria Morgendorffer (with my twist)
neonhomer is offline
post #3 of 4 Old 05-02-2012, 01:40 AM
lauderdalechad
2006 WK
If its actually cranking but not starting its most likely your fuel pressure regulator or filter (I believe the filter has a check valve in it). The problem is that once you shut the vehicle off all of the gas drains back out of the line instead of staying "primed" like its supposed to, so it takes a min to refill the lines and get the gas back up to the injectors
2000 jeep wrangler sport: 31" BFG ATS, auto - wrecked
1997 jeep grand cherokee: stock - gf's zj
2000 Silverado 5.3l Z71- sold
2006 Overland HEMI QDII
lauderdalechad is offline
post #4 of 4 Old 05-05-2012, 05:12 PM Thread Starter
chadandloren
Thanks guys! I replaced the fuel filter which was the easier and cheapest and it seems to like new again. Thanks for all the help!!!
problem starting teddybeartruck Engines & Drivetrain 3 12-04-2011 12:23 AM
Cranking problem 1987 4.0L gg1135robin Engines & Drivetrain 1 04-01-2011 05:39 PM
4.0 starting problem linkovich Engines & Drivetrain 3 12-03-2010 04:15 PM
YJ 2.5 Starting Problem OldSchoolRodz Engines & Drivetrain 0 10-02-2007 03:42 PM
YJ 2.5 Starting Problem OldSchoolRodz Engines & Drivetrain 0 10-02-2007 03:20 PM
