Crank no start - JeepForum.com
post #1 of 9 Old 11-22-2013, 12:52 AM Thread Starter
WKJeeper05
Crank no start
93 cherokee. 4.0. Cranks like crazy but won't kick or start. I've checked the CPS w another and it good. Tired throttlebody(tps included) with a good one no luck. I'm getting good spark. I've got compression. It just won't kick over or start. It will crank great though. Any help much appreciated
WKJeeper05 is offline
post #2 of 9 Old 11-22-2013, 01:23 AM
awolkiwi
Only leaves fuel would be my next avenue
awolkiwi is offline
post #3 of 9 Old 11-22-2013, 01:33 AM
shadowridr1
gotta have 3 things to make and engine run
fire
fuel
air
only one you didnt mention was fuel.
shadowridr1 is offline
post #4 of 9 Old 11-22-2013, 01:46 AM Thread Starter
WKJeeper05
Fuel is good. Got great pressure. That's why I turned to the threads. Have spark, fuel and compression. At a loss at the moment
post #5 of 9 Old 11-22-2013, 04:35 AM
shadowridr1
Wonder if it jumped time??? I had an old Chevy that did that once. Took me forever to figure that out. But with this being computer controlled. Have you checked for codes.
post #6 of 9 Old 11-22-2013, 04:36 AM
shadowridr1
Well you said you did the CPS so that should rule out the timing thing.
post #7 of 9 Old 11-22-2013, 11:09 PM
higgins192
Check and clean your camshaft position sensor, it is in your distributor cap under the rotor. Because its magnetic and metal shaving can clog the sensor. Also check your crankshaft position sensor it's on the bell housing it's worth replacing they can go bad at a moments notice and not throw a code. Happened to me. Also just check your ignition coil pack to make sure it's getting real good spark. The problem with ignition problems is you can't pinpoint them. It's kinda process of elimination
higgins192 is offline
post #8 of 9 Old 11-23-2013, 06:00 AM
uberxj92
1992 XJ Cherokee
Auto kill relay under hood. Also check the fuel pump resistor under hood.
Weak coil?
Battery voltage. Under 10ish and the ecm won't let it start.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #9 of 9 Old 11-23-2013, 05:01 PM
copmedic309
1995 XJ Cherokee
Try starting it in drive or reverse. If it starts up, could be your NSS cheaper to take apart and clean than to replace
Ry.
Rather be tried by 12, than carried by 6.
copmedic309 is offline
