Cracked Rear Main Cap - Need Advice - JeepForum.com
post #1 of 8 Old 06-17-2017, 03:16 PM Thread Starter
tjs2010
Hi All,
This question is not jeep specific, but I am sure there are some good motor heads on here that can offer advice on an outside build. I am currently working on a complete restore of a '73 Triumph TR6. I received the block back from the shop to begin reassembly and in going through my parts realized my Rear Main Bearing Cap is cracked. I am not sure if it happened when the previous owner had it or when I was disassembling. The issue is this is not a part that can be easily replaced. The only replacement parts available are a full set of CNC aftermarkets running for $500 for the set!!!! Other replacement option would be to pick up a cheap block for $400 to get the cap, but then paying a shop to line hone I end up past the point of the CNC ones - realizing those too would also need to be line honed as well. That said, looking at the crack I want advice on the below as possible options:
1. I find a shop to CNC me a replacement and hopefully save some cash over the full set. Anyone out there on Long Island capable of doing this?
2. Can this be spot welded?!
3. Or where I am potentially leaning towards - can I leave it as is? Given the location of the crack and how the bolt passes through both pieces would the 55ft lb of torque suffice to ensure proper seal? When bolted down as is, and checked with plasti I am still well in range for my recommended clearance.
Pictures below.
Thanks
2001 TJ - "The Toy" - Basically stoc at this point. 4.0 Auto
2013 Grand Cherokee TrailHawk
tjs2010 is offline
post #2 of 8 Old 06-19-2017, 08:20 AM Thread Starter
tjs2010
bump! anyone have some advice to offer?
tjs2010 is offline
post #3 of 8 Old 06-19-2017, 11:11 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
I certainly wouldn't use that cap. The crack is only going to grow until it's all the way through, at which time it will crack the bearing and trash the crankshaft.
I wouldn't trust welding it either. That could warp the whole cap slightly, then it just won't fit right. Might bolt on, but doubt the bearing would be perfectly square.
I'd start making calls to CnC shops or looking for a used engine you can scavenge from.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #4 of 8 Old 06-19-2017, 02:22 PM
222Doc
222Doc's Avatar
I agree^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
But if i had to weld that. first off only if it was forged not cast. I would weld it on the block torqued to specs or a fixture and would even pre heat it just so it dont get a odd warp as you burn it in. but first after torquing that down i would grind into the crack as best one can to get better penetration. then weld it and peen the welds. hope for the best but that is a Macgyver fix really.
222Doc is offline
post #5 of 8 Old 06-19-2017, 07:37 PM
rjbruzan
I would not want to run it but I might. What does the machine shop say? It will be in compression and may have been like this since new?
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #6 of 8 Old 06-30-2017, 10:33 AM Thread Starter
tjs2010
I spoke with a race shop by me who said it can be welded. I sent it out to them to take a look and see what they can do. If not I would need to go the CNC route as the parts are rare for this. Since this is the first time the motor has been pulled apart (to my knowledge)it could have very well been that way from day one.
tjs2010 is offline
post #7 of 8 Old 07-01-2017, 11:54 AM
rjbruzan
Thats why it would be probably be ok to run it.
rjbruzan is offline
post #8 of 8 Old 07-01-2017, 12:20 PM
jay-h
I don't think it's good to mix the caps from different blocks, especially older ones. Typically they were bored as an assembly.
If a racing house thinks they can do it properly, probably worth a shot.
(BTW the TR6 is one of the best looking sports cars ever)
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
