Cracked 2nd Piston - JeepForum.com
post #1 of 16 Old 06-18-2011, 08:15 PM Thread Starter
TomJeep177
1996 FSJ Cherokee
Cracked 2nd Piston
I have a 96 Jeep Sport 4x4 with the I6. My girlfriend drove it for about 5-10 miles with it over heating because the upper radiator hose was split. Anyways I was hoping I'd just have to take off the block and change the gasket, lo and behold the 2nd piston is missing a chunk. The wall doesn't looked scratched but I had to get the head machined. Now my question is how can I remove that piston without taking the rest of the engine out, and should I take the piston block to get checked out as well? The other pistons look fine.
TomJeep177 is offline
post #2 of 16 Old 06-18-2011, 08:24 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Your terminology is a little confusing.
Do you mean you just pulled the head?
IF the cylinder walls indeed look good, then you just remove the oil pan, undo the bolts on the connecting rod, and push the piston out of the top of the block with the connecting rod attached to it. Be careful not to damage the cylinder walls though. I have little boots that fit over the bottom of the rod that stops it from scratching anything.
You will then get the new piston installed on the rod, install new piston rings, and slide it back down the cylinder using a piston ring compressor.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #3 of 16 Old 06-18-2011, 09:27 PM Thread Starter
TomJeep177
1996 FSJ Cherokee
So far I took off the valve cover, intake and exhaust manifold, and the head and saw that the piston was missing a chunk. Do you think I should also change the timing chain because it was overheated for so long?
post #4 of 16 Old 06-18-2011, 09:46 PM
leftlanetruckin
XJ on 37's
Timing chain should be in the same condition it was in before the overheat.
For the piston to be missing a chunk due solely to a coolant issue is a little bit of a mystery though. Only time I have seen melted pistons is when either a piston cooler gives way, or there is a fuel/ignition issue. I guess it could be well and truly driven into the ground with no coolant and destroy a piston or two, but a few minutes?
If it was me and I saw that, the motor would be coming out in short order mate.
But you asked a question and I answered it. IF you want to replace just one piston, then you can do it perfectly well with the motor in place, assuming number 1 is at the front as you counted.
Martin
post #5 of 16 Old 06-18-2011, 11:34 PM Thread Starter
TomJeep177
1996 FSJ Cherokee
Well my idiot of a friend screwed up the spark plug order, so could it be from that? We tried starting it, it started hard and then stalled
post #6 of 16 Old 06-19-2011, 08:43 AM
leftlanetruckin
XJ on 37's
The damaged piston from the wrong firing order? Highly doubt it myself.
Martin
post #7 of 16 Old 06-19-2011, 09:50 AM
chris142
If it got so hot that it melted a piston I'm sure the others were damaged or weakened too. I'd rebuild or replace the whole engine.
If you put a piston in it and in 2 days another piston comes apart you will be doing it all over again.
chris142 is offline
post #8 of 16 Old 06-19-2011, 07:23 PM Thread Starter
TomJeep177
1996 FSJ Cherokee
The others don't even have carbon build up or scorching at all. Could I do some sort of test on them? before removing everything?
post #9 of 16 Old 06-19-2011, 07:30 PM
leftlanetruckin
XJ on 37's
All you can do is remove them and inspect.
Looking at them from the top and saying they are fine is not the way to go in my book. As I said, it would be getting stripped down if that was my motor, but your call.
You can of course get 1 piston and slap it back together of funds are tight etc, but you will be holding your breath for the first 500 miles IMO.
Martin
post #10 of 16 Old 06-19-2011, 07:55 PM
herbiehind
they can be inspected and put right back in if you like . i would at least look for cracks .don't mess up the rings . also look for seized rings as it got very hot . make sure they're all free and loose in the lands .
herbiehind is offline
post #11 of 16 Old 06-21-2011, 06:37 AM Thread Starter
TomJeep177
1996 FSJ Cherokee
Any ideas how to get the oil pan of with the tire rod snd everything in the way?
post #12 of 16 Old 06-21-2011, 08:21 AM
chris142
Start taking whatever is in the way out of the way.
chris142 is offline
post #13 of 16 Old 06-21-2011, 10:16 PM Thread Starter
TomJeep177
1996 FSJ Cherokee
Really wish I had a lift
post #14 of 16 Old 06-22-2011, 07:15 AM
leftlanetruckin
XJ on 37's
Now you have me very concerned.
You are talking about tearing an engine apart and rebuilding it, but can't figure out how to remove the oil pan?
Martin
post #15 of 16 Old 06-24-2011, 09:08 AM Thread Starter
TomJeep177
1996 FSJ Cherokee
The the front differential is in the way, so its hard my hands up there
cracked , help please , piston
Cracked piston! 81cj Engines & Drivetrain 10 06-20-2011 06:00 PM
Which Piston is Better bds5 Engines & Drivetrain 1 11-24-2010 04:40 PM
258 piston help greyarea Engines & Drivetrain 2 09-05-2009 08:19 PM
blew a piston ferger Engines & Drivetrain 0 10-09-2007 11:24 PM
Hole in the Piston DirtyRedTJ Engines & Drivetrain 2 12-18-2003 08:36 PM
