Could my U joint be going out?? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Could my U joint be going out??
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shipp
Unread 07-06-2012, 06:29 PM   #1
mepotts
I've had a couple problems for a while now and am just now getting around to fixing them. I've got a '98 TJ with a 4.0L and a 32RH tranny. When I take off hard I get a real bad rumble, and even occasionally going into 2nd gear at high speeds. My other issue is when I put it in gear it lurches every time, both in forward and reverse.
I've been told the first problem could be either my U joint or engine/tranny mounts. I have no idea about the other. Any input is greatly appreciated!!!
mepotts is offline   Reply With Quote
Unread 07-08-2012, 02:45 PM   #2
mmerlinn
Not sure what you mean by "lurches". Lurching can be caused by the transmission slamming into gear because of toasted clutches, bad pump, or a mean shift kit. U-joints, mounts, and differential can also cause some kinds of lurching.
Rumbling can be U-joints, mount problem, or rear end.
U-joints usually have a "popping" sound when they are going bad. If they pop enough times, they will either fly apart or weld themselves together, immobilizing you for sure.
mmerlinn is offline   Reply With Quote
Unread 07-09-2012, 01:56 PM   #3
IslandTJ
Location: where I wheel: N 45º 36.663' W 123º 20.935', Oregon
Could also be track bar or control arms...
1998 TJ Moss [COLOR=darkgreen][B][SIZE=3]Green[/SIZE][/B][/COLOR] Sahara w/ numerous scratches & dents whose playground is on a tropical island that's 33 miles long and 4-12 miles wide, in year-round 82 degree weather.
[Edit] "Now jeepin in Oregon" [/Edit]
IslandTJ is offline   Reply With Quote
