Cost for swap - JeepForum.com
post #1 of 5 Old 07-24-2007, 09:03 PM Thread Starter
wahala
Cost for swap
I am changing the ring and pinon in my 2002 TJ (35 rear, 30 front). I don't have the time to do this work my self, and found a local mechanic who is asking about $440 per axle for labor, is that a reasonable price?
Thanks in advance
wahala is offline
post #2 of 5 Old 07-25-2007, 08:02 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
It seems like $300/axle is average around here.
$440 might be reasonable for your area.
Wheelin98TJ is offline
post #3 of 5 Old 07-25-2007, 09:36 AM
Kornik
Not so newbie :-)
Kornik's Avatar
Thanks in advance
Make some calls around in the range you are willing to travel. Unless you want to just depress yourself.
Here in Iowa I have a shop which does ring/pinion change with axle in car for $220. I did it with them and I'm very pleased with results. But shipping axle from Colorado and back would probably kill the deal.
Plus define "labor" - does it cover only workmanship or install kit too? I've seen some shops that charge you only for r&p and labor - which forces you to look a little bit differently on their prices.
92 XJ Laredo Mods: bored TB, 3" lift, 1-ton steering
93 ZJ Limited Mods: bored TB, K&N insert, e-fan; prothane bushings, NP242J, 3" lift, 1-ton steering; Atlas winch
Kornik is offline
post #4 of 5 Old 07-25-2007, 10:31 AM
REDLYNER
REDLYNER's Avatar
What part of Colorado are you in? I have been quoted much lower prices from several shops in CO. I have had two different shops change out mine and both ended up around $300 or so.
Are you putting lockers in, or just changing gears?
REDLYNER is offline
post #5 of 5 Old 07-25-2007, 08:26 PM Thread Starter
wahala
Thanks for all the feedback. I live in Southern Colorado, San Luis Valley. Not a lot down here, except for a lot of places to go 4 wheeling. Prices tend to be higher here as most of the work is for touristas. I am having lockers installed as part of the labor.
wahala is offline
How much would it cost....? fastredjeep Engines & Drivetrain 2 01-04-2008 05:24 PM
POV-15 Cost...? senaTTor General Jeep & Off-Road Equipment 14 12-02-2006 11:48 AM
what would it cost? OKLAball12 General Jeep & Off-Road Equipment 0 08-30-2006 06:15 PM
How much did yours cost? Willys '05 Tires & Wheels 13 05-17-2006 11:58 AM
