Coolant in transmission fluid!! - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Coolant in transmission fluid!!
Rampage Bowless Soft Top Oconee offroadAlloy USA Still AvailableAdvance Adapters SYE Kits
Unread 10-21-2014, 09:04 PM   #1
sdprivett
1997 XJ Cherokee
I just bought my first jeep! A 1997 xj country with 191k no rust! for $1900. Had it for maybe 4 days checked the transmission fluid and it was milky pink. Checked coolant and it looked like mud. Took radiator off today and going to replace tomorrow but any ideas for transmission? Don't have money to put a new one in. It has shifted perfectly fine with no hard shifts or slips but I know it at least needs flushed. I guess my question is if anyone else has had this problem and knows if I could get lucky with just the flush. I'm trying to stay positive but I've had it for under a week and already this...
Sent from AutoGuide.com Free App
sdprivett is offline   Reply With Quote Quick reply to this message
Unread 10-21-2014, 09:19 PM   #2
Boodyrider
Flush it, and pray, if it has had coolant in it long, an auto trans is going to be toast most likely. If it's is a manual, I am at a loss how coolant and trans could mix. With auto, I am afraid you'll find that friction material does not like coolant at all.
Boodyrider is offline   Reply With Quote Quick reply to this message
Unread 10-21-2014, 09:26 PM   #3
sdprivett
1997 XJ Cherokee
Thanks for the reply, it is an auto but hoping the flush and some Lucas trans fix can buy me a couple months.
Unread 10-21-2014, 09:31 PM   #4
Boodyrider
Do not use any snake oil stuff. Flush with correct fluid. You'll likely need to flush 2 or 3 times. To get the converter well flushed. Probably be atf+4 but verify that.
Unread 10-22-2014, 09:23 AM   #5
1977chieftainS
1977 FSJ Cherokee
I have a 99 xj fluids should be dexron 3 or dexmerc since dex3 is being phased out be sure to check and see if the tranfercase has coolant in it. on mine the fluid can flow between the two
1977chieftainS is online now   Reply With Quote Quick reply to this message
