coolant system problems - JeepForum.com
post #1 of 7 Old 02-07-2013, 10:36 AM Thread Starter
MattNey723
I cracked my radiator about 2 weeks ago replaced it twice since then now I have no heat and my thermostat housing cracked... I'm good with anything else in a jeep but the cooling system of an 01. Any suggestions or advice?
MattNey723 is offline
post #2 of 7 Old 08-22-2013, 12:45 AM
benc85
I have the same problem mate. Just put new one in and still getting very hot. The fan seems to be blowing air on to radiator not sucking fresh air in. I tried to turn around but its same other way. Have you sorted yours out yet?
benc85 is offline
post #3 of 7 Old 08-22-2013, 09:50 PM
uberxj92
1992 XJ Cherokee
This is weird but it sounds like you guys put your thermostats in backwards.
As for the fan blowing backwards even if you turn it around, that sounds like you somehow plugged it I'm backwards.
Did you guys change out the radiator hoses?
No heat could be ( aside from the thermostat backwards ) could be the heater control valve maybe it caused your original overheating. Check the vacuum line make sure its connected.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #4 of 7 Old 08-23-2013, 01:03 AM
andyabbot
Here is only one way to fix that issue you have to install the new radiator in the jeep because jeep will get hotter if you did not fix that issue and it will cause the major damage.
United Car Care
I am running towards death for life...
andyabbot is offline
post #5 of 7 Old 08-23-2013, 06:25 AM
uberxj92
1992 XJ Cherokee
They did replace the radiators with new ones.
uberxj92 is offline
post #6 of 7 Old 08-23-2013, 08:19 AM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Then the water pump is probably spinning the wrong way. Many jeeps have reverse direction water pumps.
EDIT!! IF the T-stat is in right.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #7 of 7 Old 08-23-2013, 12:39 PM
uberxj92
1992 XJ Cherokee
Check belt to make sure its routed right
uberxj92 is offline
