coolant leak - JeepForum.com
post #1 of 6 Old 08-24-2005, 05:54 PM Thread Starter
trojan man
coolant leak
I have a coolant leak on my zj that comes from the frame somewhere (thats where I can see it coming out). Anyone got any advice for me?
Thanks
trojan man is offline
post #2 of 6 Old 08-24-2005, 06:06 PM
jadams68
jadams68's Avatar
From the frame? More info needed... Where exactly... be more specific.
Here's a list of culprits...
1) Water pump weap hole...when the water pump begins to go, it will piss small amounts of coolant out of the weap hole.
2) Water pump gasket
3) Radiator hoses
4) Radiator
5) Thermostat housing gasket
6) Freezeplugs in the engine block
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #3 of 6 Old 08-24-2005, 11:29 PM
nwdriftking
I just had this happen to me. The leak was coming from my water pump. I replaced my radiator hoses and clutch fan while I was at it because the hoses were a little mushy and the clutch fan was a little wobbly. I took it to my local radiator shop and it cost me $420 to fix.
nwdriftking is offline
post #4 of 6 Old 08-25-2005, 04:17 PM Thread Starter
trojan man
It is coming from the passenger side probable 2 feet from the middle of the car
post #5 of 6 Old 08-25-2005, 05:40 PM
jadams68
jadams68's Avatar
That helps... could be the heater hoses going into the firewall or a leaking freeze plug...
jadams68 is offline
post #6 of 6 Old 08-25-2005, 10:44 PM
dadjlh
Check under your passenger side carpet. I'll bet it is A/C leaking under carpet and draining out through frame. Been there and done that.
1994 Grand Cherokee Limited (Silver)
4.0 I6 42RE
NP242
Dana30/Dana 35C 3:73
1988 Comanche Pioneer (Blue)
4.0 I6 AW-4 2WD
D35C Rear Axle
dadjlh is offline
4.0 Headgasket leak coolant sludge- HELP 93ZJbeast Engines & Drivetrain 2 08-01-2008 09:18 AM
Coolant Leak Clarifications StokedXJ11 Engines & Drivetrain 4 01-24-2006 07:55 PM
Coolant leak....freeze plug?? Spankee Engines & Drivetrain 1 07-21-2004 04:43 PM
Help! - 4.0L I-6 Coolant Leak Brian's 97 ZJ Engines & Drivetrain 9 07-01-2004 03:22 PM
Coolant Leak...HELP!!!! TJDUDE6 Engines & Drivetrain 1 11-10-2001 07:58 PM
