Coolant leak - JeepForum.com
post #1 of 6 Old 08-17-2013, 01:37 PM Thread Starter
G1116
Coolant leak
Where is the most common place a leak will occur on a radiator? And is it easy to fix?
G1116 is offline
post #2 of 6 Old 08-17-2013, 09:21 PM
uberxj92
1992 XJ Cherokee
Usually it'll split the seam where the plastic meets the aluminum
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #3 of 6 Old 08-19-2013, 01:29 AM
road2rage
May I ask if you know for sure it's your radiator or just a coolant loss?
road2rage is offline
post #4 of 6 Old 08-20-2013, 12:44 PM Thread Starter
G1116
The fluid on the ground is green
G1116 is offline
post #5 of 6 Old 08-20-2013, 10:56 PM
uberxj92
1992 XJ Cherokee
Go to parts store rent pressure tester for radiator. That'll give you an idea
uberxj92 is offline
post #6 of 6 Old 08-21-2013, 08:32 AM
vadslram
I just traced my leak down. The tranny cooler was snugged to the tank with a nut and rubber washer..the nut backed off a little and it was dripping past it. Two turns and the leak stopped
vadslram is offline
