-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   Coolant leak (http://www.jeepforum.com/forum/f19/coolant-leak-1563477/)
G1116 08-17-2013 12:37 PM
Coolant leak
Where is the most common place a leak will occur on a radiator? And is it easy to fix?
uberxj92 08-17-2013 08:21 PM
Usually it'll split the seam where the plastic meets the aluminum
road2rage 08-19-2013 12:29 AM
May I ask if you know for sure it's your radiator or just a coolant loss?
G1116 08-20-2013 11:44 AM
The fluid on the ground is green
uberxj92 08-20-2013 09:56 PM
Go to parts store rent pressure tester for radiator. That'll give you an idea
vadslram 08-21-2013 07:32 AM
I just traced my leak down. The tranny cooler was snugged to the tank with a nut and rubber washer..the nut backed off a little and it was dripping past it. Two turns and the leak stopped:2thumbsup:
The time now is 03:10 PM.
