coolant flush write up? - JeepForum.com
post #1 of 2 Old 08-27-2013, 11:25 AM Thread Starter
norin_radd
anyone know of one? or care to quickly explain. so many different things ive read. which hose to disconnect. wich one to burp. when to run motor. when to add fluid. ect
norin_radd is offline
post #2 of 2 Old 08-27-2013, 12:59 PM
Holder350
1995 XJ Cherokee
Best way I have found is to pull the upper radiator hose and stick a water hose in the upper radiator inlet.
Turn the water on low to keep the radiator full, start the motor and turn the heater on.
When the water runs clear from the upper hose (after the motor has warmed up and the thermostat has opened) you can drain the water from the radiator and refill with antifreeze.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
