coolant flush - JeepForum.com
post #1 of 7 Old 11-30-2012, 07:46 AM Thread Starter
demonoid369
1997 XJ Cherokee
coolant flush
bought the prestone radiator flush kit but I realized it involves cutting one of the radiator hoses which has me on the fence about doing it. is there any other option or bypass that doesn't involve doing something permanent to the system?
demonoid369 is offline
post #2 of 7 Old 11-30-2012, 07:48 AM
FLATFENDER54
FLATFENDER54's Avatar
Its not that bad. Ive cut my hose. .......... my motor did blow up later though??? Hmmmm................
01 TJ Sahara 4"short arm/rear gas&tire
carrier bumper/front winch bumper winch/detroitEz
1954 WILLYS CJ3B (under construction)
FLATFENDER54 is offline
post #3 of 7 Old 11-30-2012, 08:44 AM Thread Starter
demonoid369
1997 XJ Cherokee
I'm not expecting a blown up engine but I dont know how strong or sealed the valve is that goes on to the hose. hence why I am on the fence about it. now if it was a coolant filter with a metal shut off valve like the how to shows for that set up, Id be fine but this set comes with what looks like a plastic one
post #4 of 7 Old 11-30-2012, 10:15 AM
FLATFENDER54
My engine really did blow up...unrelated though. lol The hose and plastic fitting has held up fine though
post #5 of 7 Old 11-30-2012, 05:29 PM Thread Starter
demonoid369
1997 XJ Cherokee
So after flushing the system do you just cap the t-fitting and call it good?
post #6 of 7 Old 11-30-2012, 09:35 PM
RagBag
If your worried why not replace the heater hose afterword? The heatercore in my truck blew so I bypassed It with the tee. a zillion miles later its fine.
Chances make champions
RagBag is offline
post #7 of 7 Old 11-30-2012, 11:46 PM
RagBag
BTW depending on the miles you have maybe you should replace ALL of the hoses, belts, etc.
RagBag is offline
