Quantcast cold air intake - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > cold air intake
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!TJ WW2WW rockers on sale with free gaskets this month.
Old 04-16-2005, 10:50 PM   #1
urwaker
cold air intake
im running a 98 TJ 4 stroke with 33x12.5 on a 2" RE BB and 1" BL. thinking bout getting a cold air intake. Im looking for a good brand and not too much $$$. any sugestions?
justin
urwaker is offline   Reply With Quote
Old 04-16-2005, 11:03 PM   #2
Mr. Notorious
I have the K&N FIPK that I got cheap on Ebay because it was used and I have the 6 cylinder. But I'd invest your money in other places. There was a good example in the YJ forum about installing a cold air intake on a 4banger. Basically, they already get enough air as it is, and it usually turns out to be a mind over matter type of deal. Plus, more air doesn't help unless you have a less restrictive exhaust to get rid of that extra air. Check it out here
1992 4.0HO 5spd -- BDS 3.5" lift -- 33x11.5 M/T's -- Gibson Cat-Back -- 8.8 with 4.10's -GONE
1967 FJ, linked, 350 chevy, 35's, arbs, blah blah...
2002 TJ
"If you're not moving ahead, you're falling behind"
Mr. Notorious is offline   Reply With Quote
Old 04-17-2005, 12:45 PM   #3
urwaker
thanks, awesome info in that link.
Old 04-17-2005, 05:49 PM   #4
CosmicCreeper
If your looking for a cheap intake. Goto walmart or autozone and buy one of those "J" pipes and filter maked for those ricey Hondas, they even have the fittings for the small hoses. And they cost about $30 to $60 depending on where you look. They basically replace the air box. How you want to hook it up to the throttle body is up to you. Some use the stock rubber piece from the throttle body and hook it to the pipe others replace the whole setup. It's up to you. And it's cheap and easy to find.
USN Jeep Club Hull #1
CosmicCreeper is offline   Reply With Quote
Glock Forum
