Clutch? Tranny? - JeepForum.com
post #1 of 4 Old 12-09-2006, 08:12 AM Thread Starter
ddaly29
Clutch? Tranny?
Hi,
I have a 1993 Jeep Wrangler, 4.0, 5 speed.
When I try to select 2nd gear when the jeep is cold it does'nt want to go in. After it warms up there is no problem selecting any gear. I have replaced all the fluids, gearbox, clutch etc. The clutch needs to be pressed all the way to the floor at ALL times for the gearbox not to grind..
Any feedback as to the cold, gear selection would be appreciated.
Regards
ddaly29 is offline
post #2 of 4 Old 12-09-2006, 10:12 AM
jipjip
jipjip's Avatar
these tranny's are pretty hard to shift when cold.although i don't have to have my clutch ALL the way to the floor for them not to grind. check your clutch fluid and see if your leaking any. if not, i would suggest replacing your clutch master cyl, b/c it's probably bypassing fluid causing the freeplay in the clutch to increase, making you have to push the clutch all the way to the floor to properly disengage.
this may get worse as time goes on, to the point when you will not be able to get it into gear. period.
95 yj sahara green w/ spice hard and soft top, bikini top,full steel doors, and 2 piece bestop soft doors,tnt customs front tube fenders w/ 6" flare,warn gas tank skid, skidrow oil pan skid,4.0HO,rear 31 spline 8.8 w/ disc brakes,4.10's and lsd,front HP d30 w/ 4.10's and aussie front locker,ax15,np231j w/ jb conversions ss sye, tom woods custom cv d/s,RE 4.5xd,35" toyo open country m/t's, 1" daystar body lift, warn 9.5ti
jipjip is offline
post #3 of 4 Old 11-26-2012, 06:15 PM
clhaggett
Good to know. My 89 hates to go into second when cold. I also noticed that reverse is a bit strange when cold. Definitely have to use the clutch pedal to the floor all the time on mine too.
clhaggett is offline
post #4 of 4 Old 05-23-2013, 05:29 PM
clhaggett
Well, I am going to bite the bullet and replace the tranny in my YJ. I am not sure what is in it now, besides a 5 speed manual. I would like some input on my options. I have a 4.2L I6 and will be putting 33X12.50 tire. It currently has a 2" lift and I think I will add a 1" body lift with the tire upgrade just to get some extra room. Any thoughts would be a great help.
Squishy clutch then the clutch just locked up completely is it the master, slave or ? GPII Engines & Drivetrain 1 11-25-2011 07:36 PM
Noise from the clutch or tranny Bigboyky Engines & Drivetrain 0 06-19-2008 04:20 PM
clutch or tranny prob? greenyiride Engines & Drivetrain 1 02-27-2007 02:23 PM
Tranny install, clutch, and misc Q's TellyDSP Engines & Drivetrain 6 03-28-2005 01:28 PM
clutch or tranny problems TroyBoyM General Jeep & Off-Road Equipment 3 12-27-2002 12:43 PM
