Clutch throwout bearing and oil leak in clutch housing - JeepForum.com
post #1 of 9 Old 10-23-2013, 10:48 AM Thread Starter
calvykins
Hi... I have just removed my Renault 2.1 diesel engine from my 1982 French CJ7 and have discovered that the clutch housing seems to have a lot of oil inside. Also the spline from the T5 gearbox seems to have a fair amount of play in the clutch throwout bearing.
is it possible that the oil comes from the throwout bearing or is there a seal between the clutch casing and T5 gearbox?
Thanks
calvykins is offline
post #2 of 9 Old 10-23-2013, 12:58 PM Thread Starter
calvykins
As you can see, it's been leaking oil all over the place. Certainly from the clutch housing
At least it's stopped a lot of rust forming!!
post #3 of 9 Old 10-23-2013, 08:26 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Valve cover gasket leaking down the rear of the engine.
Rear main seal.
transmission input seal leaking.
clutch slave cylinder leaking.
Any combination of the four.
jeepdaddy2000 is offline
post #4 of 9 Old 10-24-2013, 12:12 AM Thread Starter
calvykins
Thanks
What about the play in the gearbox shaft?
post #5 of 9 Old 10-24-2013, 05:18 AM
jeepdaddy2000
1971 CJ5
If your talking about the input shaft moving, there will be a small amount of vertical movement due to the input being out of the pilot bushing. What you don't want to see is fore and aft (in and out) movement. This indicates a worn bearing.
In the end, if your unsure, you can replace the input bearing.
post #6 of 9 Old 10-25-2013, 01:50 AM Thread Starter
calvykins
Thanks jeepdaddy2000. There is so much oil everywhere it's impossible to tell where the leaks are. The PO never cleaned it off, it's been there for years.
I have cleaned off all the oil now and there is no fore and aft movement of the input shaft. The tip of the input shaft can be moved about 2mm (1/10 inch) in any direction from the axis. is this acceptable? The seal coming out of the gearbox doesn't look worn. I don't want to disturb it if it's not necessary, but as the whole unit is out of the car would you recommend replacing the throw out bearing and shaft bearings and seal as a precaution?
I know that the engine sump was leaking oil so I'm hoping the oil in the clutch housing came from there...thanks for your help
post #7 of 9 Old 10-25-2013, 04:51 AM
jeepdaddy2000
1971 CJ5
The input movement sounds acceptable to me. I would skip the shaft bearing unless you feel it may be bad. Having it removed with the trans intact will take a special tool and you will probably need to get it to a professional to get it off.
If you suspect the input seal is leaking, replace it.
You need to inspect the entire clutch assembly for wear and contamination. If anything looks bad, it would probably be a good time to replace it, since as you said, the transmission is already out.
post #8 of 9 Old 10-25-2013, 08:37 AM Thread Starter
calvykins
Thanks once again...One last question for the moment..... I removed the engine from the car by sliding the engine forward until it cleared the input shaft and then lifted it out.
Can I replace the engine in the same way? By lining everything up and sliding the the engine back onto the shaft? Or is there anything else I should consider?
post #9 of 9 Old 10-28-2013, 05:17 AM
jeepdaddy2000
1971 CJ5
You can.
I would remove the motor mounts if you haven't already. I usually drop the rear driveline and leave the transmission in gear. This allows me to rotate the rear output which can help aligning the input shaft into the clutch.
You may need a jack under the transmission to get the nose up. I like to use a transmission jack, but anything will actually work. you may also need to toss a come a long on the front of the engine to lift the nose if you have to.
Be sure the engine is flush with the bellhousing before you bolt it together. some folks try to get that last inch using the bellhousing bolts and wind up snapping something.
Removing the engine is a common way to replace the clutch in a number of vehicles.
