Clutch slipping or bad mechanics? - JeepForum.com
post #1 of 12 Old 02-08-2012, 10:03 AM Thread Starter
mdplayer
So, I would like to start this off by saying that I am by no stretch a "car guy". As long as you don't tell me its the "Flux Capacitor" or "shaft bearings" or something like that, I pretty much will take your word for it..
I've been having some issues with my Jeep when I pull out, so I took it to the shop. The problem is, when I pull out, from not moving (vs a rolling stop) it feels like the back end is jumping. On a rolling stop, it does not happen. The best I can describe it is, if you pull out, and spin the tires, sometimes they jump. That is what it feels like. Its only when I pull out, and never when changing gears (I have a manual transmission). When I pull out on ice or snow, it doesn't do it as bad. If I pull out super slow and carefully, it doesn't do it. On 2 different occasions, when driving over some chewed up railroad tracks, I must have been coasting just right, and it popped out of 4th gear.
Ok, so that is the issue
Took it to a Jeep dealer to look at it (they do all my work), and they went through and found that the distributor cap was broken and figured it was rattling around and that was the problem. They replaced it. When I picked up the Jeep, it did the same exact thing (maybe to a lesser extent) when I pulled out (although the Jeep did have more pep). CRAP. So, took it back the next day, told them the same thing, they looked at it again. This time, they said they felt it, they didn't previously, and said it was the clutch slipping and going bad. They thought I could run it like that for the rest of the winter and be fine.
I have had clutches go on cars before, and it didn't feel like this. The previous car that lost its clutch, you could just feel it slipping out of gear when going up hill or something like that.
So, what are the thoughts? Think this could be a clutch slippage or should I take it elsewhere and have a different mechanic take a look at it? If it matters, I have 125K miles on my 2001 Wrangler SE...
Thanks in advance.
mdplayer is offline
post #2 of 12 Old 02-12-2012, 10:21 PM
armmata
1991 XJ Cherokee
Check the gears
armmata is offline
post #3 of 12 Old 02-12-2012, 11:33 PM
jnicewan
Does it do it when you are still releasing the clutch pedal, or does it do it after the clutch pedal is released. You explained a lot of details but I am not sure if I had enough to lean toward clutch chatter or wheel hop, sounds like you have clutch chatter.
If it does it when releasing the clutch pedal its probably clutch chatter, this problem is usually worse when the clutch is still cold and/or on damp/humid days. Its caused by irregularities in the flywheel or pressure plate, probably hotspots. Quicker clutch releasing usually decreases the problem. Some people have said that a couple hard clutch launches, or clutch slippings can make the problem go away for awhile (Im not sure that it would help though, usually not a good idea to purposely slip a clutch). It could also be leaking oil getting on the clutch too. Hotspots are usually caused by overheating the clutch or slipping it a lot on numerous occasions. Could just be getting due for a new clutch, or having one replaced without resurfacing the flywheel. There are a couple other reasons too but these are the usual ones.
If its wheel hop, it could be something like worn shocks, control arm bushings etc. Wheel hop can also be caused by clutch chatter on hard launches too. Some wheel hop can be considered normal especially with oversized tires.
jnicewan is offline
post #4 of 12 Old 02-13-2012, 03:34 AM
Technohead
Might also check rear suspenion bushings.
-Eric
Technohead is offline
post #5 of 12 Old 02-13-2012, 10:04 AM Thread Starter
mdplayer
It usually does it during the clutch release, so right when I start moving as the Jeep is just starting to move. If I release the clutch real slow, and pull out very "carefully", then I can get it to not do it.
As for the temps, at first, it almost did it less when it was warmer. But at this point, I don't think it matter much on temperature.
mdplayer is offline
post #6 of 12 Old 02-13-2012, 10:05 AM Thread Starter
mdplayer
This is almost what I was thinking.
Again, as I originally stated, I have no idea what I am talking about when it comes to cars and that stuff, but I feel like its a shock/busing/something or another going on back there. It almost seems that it is running rougher over the crappy roads here in Maine, so I feel like is all the same thing going on..
I think I will take it to a different mechanic and see what he has to say...
mdplayer is offline
post #7 of 12 Old 02-13-2012, 10:09 AM
JC_Sahara
Does it do this when you are turning from a stop? Could be spider gears? Id definitely take the rear diff cover off and take a peak inside!
My Build Thread:
JC_Sahara is offline
post #8 of 12 Old 02-13-2012, 10:11 AM Thread Starter
mdplayer
Yes, it happens when I am turning, but it happens when I pull out straight as well.
mdplayer is offline
post #9 of 12 Old 02-13-2012, 05:47 PM
wushaw
Rockin jeep
wushaw's Avatar
It could be.
warped Pressure plate
Bad clutch disk springs
bad tranny mount
bad rear suspension components
bad u-joint
bad drive shaft angle
bad driving habits
wushaw is offline
post #10 of 12 Old 02-14-2012, 10:53 AM
herbiehind
got a limited slip rearend?
herbiehind is offline
post #11 of 12 Old 02-14-2012, 10:54 AM Thread Starter
mdplayer
Unless it comes stock on the base level SE (which I am 99.999999% sure it does not), I am going to go with a big negative on that one.
mdplayer is offline
post #12 of 12 Old 02-14-2012, 12:13 PM
herbiehind
okay , you're only owner , cool . and you've obviously now, never put one in . cool . so i guess that aint it .
sounds like you're all set then .
95 jeep cherokee clutch slipping carlj Engines & Drivetrain 0 10-23-2011 09:37 PM
Help! Not even the mechanics know what's wrong! Jeef4Me Engines & Drivetrain 6 03-12-2011 06:27 PM
Craftsman 260pc Mechanics tool set SALE TJRubicon06 General Jeep & Off-Road Equipment 6 05-15-2010 12:28 AM
Mechanics in Jersey newsense General Jeep & Off-Road Equipment 3 10-25-2007 08:20 AM
?? Problem Riddling 2 Mechanics bigsems Engines & Drivetrain 3 09-30-2006 05:39 AM
