clutch problem - JeepForum.com
post #1 of 6 Old 02-12-2011, 09:59 AM Thread Starter
klc1965
clutch problem
On my 93 yj wrangler the clutch pedal became non responsive. The fluid was a little low so i added some & bled the slave cylinder. When i pumped the clutch after bleeding, the fitting came apart where the line from master cylinder ties to slave cylinder. I have reconnected the line & added fluid. While pumping clutch i get same results repeatedly. I replaced the slave cylinder a couple of years ago because fluid leaked out of it. Is my problen with the slave cylinder again? Can they get clogged up?
klc1965 is offline
post #2 of 6 Old 02-12-2011, 10:07 AM
torquewrench
Just to clarify, are you saying that each time you reconnect the line that it becomes disconnected?
torquewrench is offline
post #3 of 6 Old 02-12-2011, 10:51 AM Thread Starter
klc1965
Yes. That is correct & the clutch pedal pumping never yields any resistance. The pedal remains floppy with no resistance. It seems that the slave cyl is not pushing on the clutch at all
klc1965 is offline
post #4 of 6 Old 02-12-2011, 11:37 AM
Flyordie
1985 XJ Cherokee
hmm... Maybe the seal in the slave cylinder has failed?
Does your slave cylinder look like that?
Flyordie is offline
post #5 of 6 Old 02-12-2011, 11:52 AM Thread Starter
klc1965
No. unfortunately mine is all internal. it is a complete circle that fits around the input shaft. you have to remove the transmission to replace the slave cylinder on mine
klc1965 is offline
post #6 of 6 Old 02-12-2011, 07:57 PM
Flyordie
1985 XJ Cherokee
heh, my Jeep is a 1985 model year and it has the external one. Strange.
Flyordie is offline
clutch , slave cylinder
Clutch problem trsmith29 Engines & Drivetrain 0 09-28-2010 10:13 AM
Clutch problem popperdukie Engines & Drivetrain 1 05-31-2010 03:34 PM
Clutch Problem Hambone83 Engines & Drivetrain 1 09-10-2008 12:45 PM
clutch problem? wrxnefx Engines & Drivetrain 1 09-07-2007 01:33 PM
Clutch problem? natefoss Engines & Drivetrain 0 07-02-2007 08:49 PM
