Clutch pedal very stiff and unable to put in gear. - JeepForum.com
post #1 of 10 Old 09-02-2013, 08:17 AM Thread Starter
Jeep4x4TJ
I have a TJ and yesterday I down shifted and heard something go * tink* the clutch pedal went straight to the floor and was only responsive in the last inch or so of travel so that I was still able to shift gears. Now today I tried to drive it to the shop so I could work on it and I put it in reverse got about 15' out of the drive and the pedal went stiff and I couldn't rip it out of reverse as I was still moving with the brake held so I had to turn off the ignition to stop moving. Has anyone had any similar problems? I could use some input on this!
Jeep4x4TJ is offline
post #2 of 10 Old 09-02-2013, 08:42 AM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Have you checked the linkage that ties the clutch pedal to the clutch master cylinder?
How much fluid is in the master cylinder? If that gets low and air gets in, it causes the pedal to act weird.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #3 of 10 Old 09-02-2013, 09:05 AM Thread Starter
Jeep4x4TJ
no I haven't checked that out yet but it sounded like something broke when it first happened. I was thinking its the clutch pedal return spring but I am open to suggestions.
post #4 of 10 Old 09-02-2013, 06:11 PM Thread Starter
Jeep4x4TJ
The linkage is ok and I am not losing fluid. So I'm narrowing it down to the fork return spring or the clutch return spring.
post #5 of 10 Old 09-03-2013, 12:46 PM
schitzangiggles
King of Macastan
How many miles are on your jeep?
If it is near or over 100,000 get a new clutch kit to install since you'll be in there any ways.
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
post #6 of 10 Old 09-03-2013, 01:04 PM Thread Starter
Jeep4x4TJ
I just had the clutch replaced about 15000 miles ago and the clutch that was in it didn't even need to be changed. I have 147k on it now and will probably get another 150k out of her. I just need to fix the problem at hand first and I'm not sure if this is a common problem because when the clutch was replaced before everything else was gone over and replaced.
post #7 of 10 Old 09-03-2013, 06:40 PM
schitzangiggles
King of Macastan
I just hate pulling stuff apart to fix one thing, putting it back together and then a few weeks later, pulling it all apart again to replace the other part that broke that I could have slapped in while I had it apart the first time.
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
post #8 of 10 Old 09-03-2013, 08:12 PM Thread Starter
Jeep4x4TJ
Oh I completely agree which is why I will be checking everything over but its a new clutch already so maybe I'll replace the throw out bearing and I might take the rear end civers off to clean the gears out and replace the gear oil. Its all about preventative maintenance and keeping everything new or in like new condition!
post #9 of 10 Old 09-04-2013, 01:15 PM Thread Starter
Jeep4x4TJ
Well I thank you guys for the replies but it was definitely the fork return spring or retainer spring as mopar calls it. So I basically had to tear the tranny out for a $5.00 part go figure.
post #10 of 10 Old 09-04-2013, 02:47 PM
JeeperCreepers7
Well at least it was ONLY $5, could be much worse! Glad you got it worked out...
JeeperCreepers7 is offline
clutch problem hard push
