Clunking coming from rear.. - JeepForum.com
post #1 of 7 Old 06-04-2006, 08:31 PM Thread Starter
98kkk
I was taking off from a stop sign pretty fast and i heard a clunk clunk....now it does it whenever i get on the gas...more when i am turning but will do it when i am going straight. Could it be the trasfercase or axle?? I have a D35...its a pretty loud clunk too..sounds almost like it jumps a gear. Thanks
98kkk is offline
post #2 of 7 Old 06-05-2006, 11:00 AM
de6w6it
My buddy had this in hi 97 tj, and when he took it to a friend so they could diagnose and fix it, his friend got in it, gave it gas, and the rear end exploded. I would say take off the rear diff cover and check in there.
'66 Mustang/200/C4/ground up resto
'88 4 runner/SAS/22re/W56/duals/31's DD
Build:
de6w6it is offline
post #3 of 7 Old 06-05-2006, 02:56 PM
dakuda
Admin
dakuda's Avatar
Do you have a stock suspension?
You can do things the right way or the wrong way.
Or you can do it MY way...which is like the wrong way, only faster.
dakuda is offline
post #4 of 7 Old 06-19-2006, 05:42 PM
TJSUPE
Check your Front and rear track bars too. They may be loose.
TJSUPE is offline
post #5 of 7 Old 06-19-2006, 06:07 PM
tommaho
tommaho's Avatar
Check the suspension as others have said, but pull your rear cover and check for broken teeth on your spider gears. If you have a track lock it might just be broken down fluid, but it doesn't sound like it.
Tom
tommaho is offline
post #6 of 7 Old 06-19-2006, 06:46 PM
battallion14
battallion14's Avatar
Check the rear end as mentioned and also grab hold of your rear shocks and shake them to make sure they are still firmly in place. You wouldn't be the first to break a bar pin or have a shock slip off the bushing.
battallion14 is offline
post #7 of 7 Old 06-22-2006, 07:57 PM
tommaho
tommaho's Avatar
So what was it?
I hate finding old posts in my searches where the OP shows up with a question or problem but never follows up with whatever answers he's found for the benefit of others.
tommaho is offline
Need Help with Clunking Noise tuesday861 Engines & Drivetrain 2 09-29-2008 02:40 PM
PLEASE help me with clunking noise!!!! Johnnyjeep98 Engines & Drivetrain 4 07-21-2008 02:27 PM
Rear Breaks (or axle?) Clunking agie Street Jeep Forum 19 05-28-2006 02:51 PM
clunking noise pyro247 General Jeep & Off-Road Equipment 13 12-12-2003 11:54 AM
