Clocking a transfer case - JeepForum.com
post #1 of 20 Old 12-20-2011, 03:09 AM Thread Starter
Motas
1983 CJ10
Hi. I have been searching and cannot find what clocking does. Can anyone please explain? Im planning a tummy tuck at chassis rail level and clocking kept coming up. Before anyone says it yes i realize i need to chop the interior up. That is fine with me.
Thankyou.
http://cj10camper.blogspot.com.au/
Motas is offline
post #2 of 20 Old 12-20-2011, 03:29 AM
gunner44
It is a word used by those who know what tummy tucking is.
gunner44 is offline
post #3 of 20 Old 12-20-2011, 03:35 AM Thread Starter
Motas
1983 CJ10
Thanks for such a useful and knowledgable answer to my honest question. If anyone has anything useful to add to this discussion I thankyou. Otherwise please refrain from posting.
Motas is offline
post #4 of 20 Old 12-20-2011, 03:46 AM
gunner44
Didn't mean to p--- you off
gunner44 is offline
post #5 of 20 Old 12-20-2011, 03:48 AM Thread Starter
Motas
1983 CJ10
Well it sounded a lot like it.
Motas is offline
post #6 of 20 Old 12-20-2011, 03:52 AM
gunner44
Did you mean locking, like in, locking a differential?
gunner44 is offline
post #7 of 20 Old 12-20-2011, 04:14 AM Thread Starter
Motas
1983 CJ10
No it was called a clock plate for transfer cases. Ill see if i can find one again. If you thought i meant locking i can see where your coming from lol.
Motas is offline
post #8 of 20 Old 12-20-2011, 04:17 AM Thread Starter
Motas
1983 CJ10
http://www.northwestfab.com/tcaseclockingrings.html
It came up in a few google results when i was researching tummy tucks and im not sure what it does. My guess is that it allows the transfer case to be moved by putting an adaptor between the engine and tc. I always wondered how the tc could be raised without moving the engine as well. In case i have anything wrong im not done researching.
Anyway if anyone could explain what clocking does it would be much appreciated.
Thankyou.
Motas is offline
post #9 of 20 Old 12-20-2011, 07:54 AM
my73CJ
1973 CJ5
When you clock the tcase you rotate it upward to create more ground clearence. Often an adapter plate is needed between the tcase and the transmission, Novak and Advanced Adaptors sells them. Not all tcases can be clocked.
my73CJ is offline
post #10 of 20 Old 12-20-2011, 08:24 AM
grandboost98
when i had to clock the t case in a yj i had, you actually re drill the holes on the output flange on the trans
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #11 of 20 Old 12-20-2011, 08:46 AM
biffgnar
biffgnar's Avatar
If you want to be a smart *** at least learn what you're talking about!
Romney in 2020!
biffgnar is offline
post #12 of 20 Old 12-20-2011, 08:49 AM
biffgnar
biffgnar's Avatar
Thankyou.
Its not raising the entire case, its rotating it around the axis of the transmission output. This can create space by move the front output side of the TC up. It can though then mean mounting holes between trans and TC don't line up so you need an adapting ring.
Romney in 2020!
biffgnar is offline
post #13 of 20 Old 12-20-2011, 09:27 AM
1986cj
If you look at the mounting holes on the back of the transmission and look at the holes as it was the face of a clock. (Hense, clocking ring) The ring will bolt up to the face of the transmission just like the transfercase does. Now the ring will have a new set of holes to mount the transfercase to. Some will have 3 or 4 choices to mount to but say the one before the ring was at the 4 o-clock position you can now use the 3 o-clock position and this will rotate the transfercase and the lower part will raise up to be flatter. You can also use one with a AX15 or a NV3500 to mount a Dana 300 to it and change it from a drivers side drop to a passenger side drop and use it in a CJ.
1986cj is offline
post #14 of 20 Old 12-20-2011, 10:43 AM
gunner44
Being a neophyte , a converted heathen, I had never herd of a Tummy Tuck. When clocking was found in researching it by Motas, another, I guessed, acronym, in the jungle us heathens find ourselves in, Motas would find that as funny as we did. I was wrong, and got out of it the best I could. With all this I have learned a lot, through the help of 1986cj. A Tummy Tuck would get rid of the line I put down the center of our dirt road, Clocking is a way of describing the movement of my TC.
gunner44 is offline
post #15 of 20 Old 12-20-2011, 02:44 PM Thread Starter
Motas
1983 CJ10
Thanks for your help guys i understand now. Would there be any real point in clocking it over raising it up with a flat chassis to chassis plate? I realize it needs to be braced and body modified.
Motas is offline
Transfer Case weems Engines & Drivetrain 0 03-29-2010 04:45 PM
NP 231 transfer case. chain slapping case jetmech135 Engines & Drivetrain 1 01-01-2010 05:49 PM
xj transfer case into a yj? Kraxen Engines & Drivetrain 0 09-21-2009 07:51 AM
Transfer Case mxz583 Engines & Drivetrain 1 08-29-2009 10:52 PM
Clocking/Rotation of X-fer case TheNerd Engines & Drivetrain 0 11-20-2006 02:35 PM
